Question about IBM SureMark Printer TF6 Thermal Label
Driver ibm 4610 TM6/tf6 printer - IBM SureMark Printer TF6 Thermal Label
marked
  • 6487 Answers
SOURCE: problem printing with IBM 4610 TF6
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
Posted on Aug 28, 2008
  • 148 Answers
SOURCE: Could some1 send me the driver for 4610 suremark
Here is the current driver for the suremark 4610;
FTP
Posted on Dec 12, 2008
  • 37 Answers
SOURCE: I have a IMB 4610-TF6 and it's making weird
ummm did make sure your .exe was in english first?
Posted on Sep 06, 2009
Testimonial: "Hi Solution #1, Thanks for replying. When I install the driver, there is no option to select English. I am using a RSS Port and select COM2 as the por"
SOURCE: Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
Posted on Nov 19, 2009
SOURCE: driver IBM printer 4610 suremark for windows xp
You can find the driver here: http://www-01.ibm.com/support/docview.wss?rs=219&uid=pos1R4000123
Posted on Dec 09, 2009
Problem printing with IBM 4610 TF6
Aug 28, 2008 | IBM 4610 TG4 Thermal Label Printer
Sep 06, 2009 | IBM Office Equipment & Supplies
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Mar 26, 2009 | IBM SureMark Printer TF6 Thermal Label
Cannot get printer to print
very possible but you may need to disable the firewall if you have one then disable the antivirus . then try to reinstall software for the printer and follow directions closely. biigg53566
Dec 05, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4 offline.
if it printing trash more than likely you have a driver problem, where are you getting the driver for your printer?
try to look for another driver and test by going to ibm's website:
http://www.ibm.com/products/finder/us/finders?Ne=5000000&tmpl=%2Fproducts%2Ffinder%2Fus%2Fen%2Ffinders&finderN=1000188&pg=ddfinder&lc=en&cm_re=other-_-suprcn-_-download&collectionN=0&sid=304421691223506248263&cc=us&C1=5001220
good luck!
Oct 08, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM SureMark Printer TF6 Thermal Label Logo
682 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
