Question about Apple iPod nano
IPOD 2GB LOCKED UP
MY IPOD IS LOCKED IN A LOW BATTERY STATE. IT IS BEING CHARGED BUT NOT RESPONDING.
  • rebecca clark May 31, 2008
    red circle appears on screen with red line through it and it wont let me do anything else
    Problem Solver:
  • 6 Answers
I would recommend getting a a firewire and directly charging it through the wall outlet using an adapter..much faster
it doesnt cost too much to but the adapter considering the fact that it charges real fast.and once its charged up..make sure you turn it off when not it use and lock it ...
regards
Posted on Jun 05, 2008
    Sergeant:
  • 284 Answers
Let it charge fully
if it doesnt charge, then the USB cable is bad
the pins can be pushed back and wont charge
so get a new cabel and get it charged!
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
My ipod turns itself on, even in the lokced
My ipod turns on in the locked position also.
Dec 31, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano 2gb screen locked
You can follow this link it will give the details of ipod screen lock http://support.apple.com/kb/HT1350
Jun 18, 2009 | Apple iPod nano
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 13, 2009 | Apple iPod nano
I do NOT want to Pay for a solution ONLINE.....because after 12 hours of work on it, and internet feedback, I am SURE it is a Hardware GLITCH.....It has happened to others......so I am Not sure ,,,,but probably will have to take to China's 1st apple store
Let me Know if HARDWARE or Other Glitch.....CHARGED remains when I turn it Off until VERY LOW Battery + Kills it
dk
Aug 02, 2008 | Apple iPod nano
My ipod is locked
write ur problum properly.
Jun 29, 2008 | Apple iPod nano
Battery Problem?
It's possible you damaged the battery but not likely. The ipod has a circuit inside it to prevent overcharging (i.e. it stop scharging when the battery is full).
I would try the five R's at apple's website and then try charging it again and see if it fixes the problem.
See the five R's here:
http://docs.info.apple.com/article.html?artnum=303940
Jan 29, 2008 | Apple iPod nano
Apple iPod nano Logo
61 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
