I have a heil furnace ac is working heat wont come on?
    Scholar:
  • 80 Answers
Check the white wire is making contact well in the t-stat.
Is it gas heat or electric/heatpump
If gas then check your flame ignition system to determine if it is lighting a pilot or has a hot surface type glow element. If it does not sense the flame it will refuse to run gas for heat and or check that the electric enducer fan is comeing on before the pilot even attempts to light. It must run to prove a draft induction exist for the furnace baffles before it will attempt to start heat.
If it is a heat pump then it should fail to heat side on the reversing valve and not really need to be checked since your AC works. The call for AC has reversed the valve to even get cooling. So it is going to be heat strips failing or sequensers failing maybe even low refrigerant on a heat pump system. I know this is all a bunch to digest remember it is usually electrical and just a loose wire! So start from there and T-stats do go bad just because they can!
Posted on Oct 08, 2010
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
Heil furnance blows out cool air but not heat.
heatman101
Jan 04, 2011 | Heating & Cooling
Furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Oct 17, 2009 | Heating & Cooling
Heil Max Performance 10 Heat Pump not working
First check to see if you have afloat switch inside the air handler ar underneath the air handler. Its purpose is to shut the outside ac off if the drain stops up. Very common. If this is OK take cover off unit and with screw driver push in the contactor. It is located about the middle of the panel. It has main power at the bottom. If unit comes on you cave a control voltage problem. Meaning something is not allowing 24 volts to the contactor. If your out of Refrigerant the low pressure swich will have it off. Call a service tech. Rusty
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
295 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
