Question about Linksys Wireless-G WRT54GS Router (e125894)
Connecting wireless-g usb network adapter need web key for 64-bit or 128-bit
  • 298 Answers
You can find in on your router's setup page. What is the brand or the model of your wireless router?
Posted on May 29, 2008
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
HOW TO CHANGE SSID
Nov 08, 2010 | 2wire (1000-000057-000) Modem
My internet connection keeps dropping out with my new WL adapter. I installed a new Trendnet Router at the same time. The main computer seems to be working fine, but my wireless connection is worse than...
1)Open NETWORK CONNECTIONS from CONTROL PANEL
2)Right click on the connection and select PROPERTIES.
3)There should be a tab for WIRELESS NETWORKS.
4)Find your network by name near the bottom and click REMOVE.
5)Click ADD then you will need to enter your network information manually in the window that pops up. You will need to uncheck the box that says "My key is provided automatically"
SSID is the network name.
NETWORK KEY - This is the important one. get it wrong and click OK and when you go back in to modify it Windows screws up and saves it wrong. You can enter network keys in ASCII (typed letters) or the HEX that the router converts the key into. 5 ASCII/10 Hex is for 64 bit, 13 ASCII / 26 HEX is for 128 bit. Your key must be one of these 2 lengths.
Nov 04, 2010 | Trendnet TEW649UB Mini Wireless N Speed...
Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
    The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Does not save wireless security settings
    2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
    5. Restart your PC
    Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
    Wep
    WEP
    1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
    2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
    3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
    4. Click Security under Wireless menu
    5. Under Security, Select 64 bit WEP (or 128 bit WEP).
    6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
    7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
    Configuring WPA-PSK Encryption:
    4. Click Security under Wireless menu.
    5. Under Security Mode, select WPA/WPA2-personal (PSK)
    6. Select WPA2-PSK as your Authentication
    7. Select AES as the Encryption Technique.
    8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
      Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
    9. Click Apply changes to save the settings
      Jun 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
      WEP Encryption
      It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
      Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
      WEP Encryption
      Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
      Linksys Wireless-G WRT54GS Router (e125894) Logo
      24 people viewed this question
      Top Linksys Computers & Internet Experts
      Prashant M
      Prashant M
      Michael Galve
      Michael Galve
      Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
