Question about Uniden Cell Phones
I baught a uniden corless telephone through best buy and it doesnt work is there some trouble shooting i can do to get this phone to work
    Problem Solver:
  • 20 Answers
Prolem in boards
Posted on Oct 08, 2010
How can i bypass a forgotton pin number to set up voice mail on my uniden dect 6.0 corless phone
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download the manual. The manual will tell you how to change the PIN and set up the voicemail system.
Mar 10, 2012 | Uniden DECT 6.0 Cordless Phone ID
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
I buy This Uniden corless phone Model EZA12997 no Instrucion Inside can you sen me thre manual thanks
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EZAI2997om.pdf
I can't send it to you since you didn't publish an email address.
Sep 16, 2011 | Lands Phones
How do I get rid of the message flashing red light on my uniden dect 6.5 corless phones?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 24, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have a uniden dect 6.0 corless phone with anwering machine. I can't figure out how to record a new outgoing message
Specify the model of your answering machine from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Apr 21, 2011 | Uniden DECT 6.0 Cordless Phone
We have a Uniden Cordless Phone Model EXS9995 the volume is low, we have trouble hearing calls received. We have checked the batteries and they are OK. Can we get this fixed? Is thee someplace within...
Holy Mackeral that is an old phone! But the DSS 900 MHz are still the best for range. Lets see as old as it is the earpiece may be clogged with makeup (rouge and foundation build up pretty bad on telephone earpieces.) I would very carefully use a tooth pick and see if you can scrape anything out of the holes at the earpiece, be careful as you do not want to puncture the speaker. If that doesnt work post again and we will try something else. BTW, how long have you had the phone and when did the problem start?
Jun 22, 2010 | Uniden Cordless Phone EXAI985
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Need online owners manual for uniden cordless phone model # DCT7585-3
GO TO UNIDEN.COM CLICK ON OWNERS MANUAL THEN GO TO CORLESS PHONES THEN CLICK ON PRODUCT DETAILS AND LAST DOWNLOAD PDF.
Feb 24, 2009 | Uniden DCT7585-3 Phone
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
Cell Phones Logo
24 people viewed this question
Top Uniden Cell Phones Experts
castletech
castletech
Shehu Pro
Shehu Pro
Are you an Uniden Cell Phone Expert? Answer questions, earn points and help others
