Question about Microwave Ovens
I was given the micro without insructions. i've worked out how to cook but not to set it and work it properly. i need some instructions
  • 2 more comments
  • Kelly
    Kelly Oct 08, 2010
    We need to know make and model number of your microwave. I am being nice here.. I just can't help you without that information. I could pick one but I would most likely would not pick the correct one.
    Kelly
  • Rogena Styles
    Rogena Styles Oct 11, 2010
    i did put it on here before the question however here it is again. PANASONIC NNE424MB. i hope you can help.
  • Kelly
    Kelly Oct 11, 2010
    This is the Panasoinc global site. http://panasonic.net
    Then I checked US, Australia, Japan global and UK sites for your manual using NNE424MB. Is there a model number error in your posting? Nothing is coming up at all using Panasonic sites.
    Kelly
  • Rogena Styles
    Rogena Styles Oct 12, 2010
    -hi kelly. on the back the modwel nuber is the same with BPQ added on tne end. the serial number is W8402381. Matsuchita uk ltd also on there. i,m a novice on here so i hope you can find instructions.
  • Microwave Ovens Master
  • 3,740 Answers
I will keep looking. So far the only thing I found via the NNE424MB number it 3 replacement parts in the UK at ONE source for a unit that has at least 65 components. This is not good sign. I am still on the hunt. Be patient I don't think this is going to be quick and to be honest Panasonic may be you only hope. (searching!!!!)
Kelly
Posted on Oct 12, 2010
  • 2 more comments
  • Rogena Styles
    thankyou kelly
  • Kelly
    Kelly Oct 16, 2010
    Hi again, Just to let you know using this model number NNE424MBBPQ I did find a service manual but it is $19.95. Here is the link: http://www.manualzone.com/ShowProductsFo...
    I am searching yet again for the User's Manual / Instructions for use. So far no luck yet again using UK, US and Canada sites.
    Is this a commercial unit by chance?
    Kelly
  • Kelly
    Kelly Oct 18, 2010
    I gave it one last chance and again came up empty handed. Try contacting them here and see if by chance Panasonic UK can work some historical file magic for you:
    http://www.panasonic.co.uk/html/en_GB/Su... us/E-Mail/544169/index.html
    Gave it my all... Sorry I could not do better for you. Thanks again for giving us at FixYa a chance to help possibly you.
    Kelly
  • Kelly
    Kelly Oct 18, 2010
    The phone numbers were omitted from my last on line post (sorry)
    Panasonic UK
    Home AppliancesMonday to Thursday 9:00 - 17:30 and Friday 9:30 - 17:300844 844 3852
    0844 844 3868
How doi re progam my Panasonic counter top from demo mode to ther mode to progam and heat and warm up timed dinner plate and heattimed hot meal or beverage give ne insructions of what to do
A common answer to this for Panasonic microwaves is "4 presses of the Timer On/Off button" toggles Demo on and off.
Without you specific model, I can't be more specific than that.
Dec 25, 2014 | Panasonic Microwave Ovens
Dead panasonic nnp294 microwave
You problem will be with either the Magnetron or the Inverter. The mags are around 100.00 the inverters are much more. Sometimes it is BOTH parts. There is a signal that goes from the main board through the inverter and back to the main "PC" board, if something doesnt report properly, or the signal doesnt get through, it shuts itself off as a safety feature. Sorry, yes, costly repair. Probably time to get a new one. I reccomend one without the inverter. I find them a pricey pain in the bottom. Good Luck.
Oct 09, 2017 | Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a new Sanyo EM-C877B microwave and following instructions in the manual 3.Microwave cooking or any cooking options I will select the Micro Power 1000W then press Start, turn the dial to choose a...
I suggest you revisit the instruction manual and ensure the new microwave is not performing as per instructions.
If that is so you should contact the supplier without delay.
Sep 08, 2017 | Sanyo EMC8787B Microwave Oven
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
My microwave doesnt work
good day, try to check your cooking settings. tnx
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
