Vhs player eating tape
This dvd recorder/ vhs player was puchase last december and used only a few times. It now eats the vhs tape. I am able to get it out in one piece,and I've tried a few vhs tapes...none work
    Sergeant:
  • 291 Answers
Hunnn....Eats the tapes, with salt & paper?..just a joke!
The tape runs on a guide ( sort of a tiny ledge )when it is fully engaged. The tape cartgage is loaded ' sucked ' in with gears that drop the cartage on top of other switches to give direction, so that "fingers" pull the tape towards the reading\recording heads. When the tape IS aligned properly, BUT is locked in the proper position the tape will NOT touch the upper or lower "ledge" that keeps it accross the heads.When the tape is NOT aligned the upper or lower tape WILL touch causeing damage. OPEN THE CARTGAGE ,Look to see if the upper & lower of the tape is damaged. Now when you say "eats the vhs tape" Does the tape comes out WRINKLE, CRINKLED,CRAMPED UP??? Then that could be ANY wheel with a black rubber rim. going bad. replace if you can. but they are VERY HARD TO FIND if u don't know what u are doing.
Posted on May 30, 2008
Went i put a tapes my vhs it just eating the tape up and it cuts off
You need to purchase a VHS head cleaner or clean the heads and pinch rollers by hand. remove cover and lid to drive system. you will see all the tape guides, rollers and heads. use Q-tips and denatured alcohol and clean every thing the tape touches. swap q-tips as they get dirty.
May 07, 2014 | Magnavox Dvd Vhs Vcr Player Recorder
We purchased this unit a few years ago, but used it mainly as a DVD player. We have a few boxes of VHS movies we want to convert but the VHS "eats" tapes. I removed the top cover to see if there was d
If it was never used and now is eating tapes, there is a chance that it needs to be cleaned. The fix means that you have to take it apart and see if the tape is seating all the way, if the transport mechanics are picking up the tape and that all the rollers and guides are working. There are also rubber belts on the machine and they stretch. That means that some pulleys are not working like they are designed to and therefor the tape is bunching up and it is ruining the tape.
Nov 11, 2013 | ASUS G74SX-RH71 - G74SX-RH71 17.3 LED...
Vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.
What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.
Its called eating tapes.
With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
May 26, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
The camcorder eats tapes in record or playback modes
O heck my friend, the reason cameras eat tapes is simply because the capstan and heads need cleaning, odd how everyone forgets cleaning these last 10 years.
David
Jun 26, 2010 | Panasonic PV-L751 VHS-C Analog Camcorder
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Eats Tapes
clean all moving parts.
May 02, 2008 | Broksonic DRVCR900 DVD Recorder/VCR
VCR eating tapes when attempting to rewind
VCRs are so cheaply priced these days that it's not worth the time and trouble to fix them or have them repaired. If you fix one worn or slipping belt, another problem isn't far behind.
Feb 26, 2007 | Symphonic WF802
Televison & Video Logo
742 people viewed this question
Top Televison & Video Experts
