Question about D-Link DP 301U (DP-301U) Print Server
D-LINK DP301U I bought this print server and have installed the software but it doesn't seem to work. I have a HP2350 all in one printer and I am running Windows XP.
  • 1 more comment
  • Yakim4ik Jun 11, 2008
    hp laserjet 1018 don't connected to DP-301U
  • paulcham Jul 04, 2008
    I have the same problem with a new 301U, and the 101P+ I just replaced, needlessly I think. The 101P worked until I replaced my D-Link router with a 2 wire Gateway 2701-Hg (modem & router combined.). What's happening with both of them is that I can do a print test from within PS Admin, but not from the printer properties test (an HP1320)
    Doesn't make much sense to me -Any ideas?
  • deanata Dec 04, 2008
    i can print form PS Admin but not from any other applications. HP 2410xi.
    i have DP-301U set same as default 192.168.0.10
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
Posted on Jun 03, 2008
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
I can't get the default ip address
Dear May,
You can download the softwares which can show you the exact ip of your device
http://www.hide-windows.com/Download/ipscan.exe
or you can download the PSADMIN software from this link ftp://ftp.dlink.com/Printserver/dp301u/Apps/PSAdmin/DP301U_PSAdmin_100.zip
it will automatically show you all the connected Print Servers,
Click on IP icon and it will prompt you for the password, Enter the password (default= admin) if you haven't set your own and it will show you the IP
Regards, Bilal Kindly Vote for this solution too :)
Jan 11, 2011 | D-Link DP 301U (DP-301U) Print Server
What is the difference between d link DPR 1020 and DP-301u
One of the main difference between this tow printer is the DPR1020 is made to work with all printer including those multi function printers , because this old DP301U was a older version of print server that don't support those new multi function printers features like scanning and fax. So if you have a multi function printer I will advice you to get the DPR1020 so all features of that printer will work behind this print server.
Aug 16, 2010 | D-Link DP 301U (DP-301U) Print Server
What is the ip?
default IP address of DP-301U is 192.168.0.10
Jul 14, 2009 | D-Link DP 301U (DP-301U) Print Server
D Link DP301U not working with a Canon MXF series printer
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Jun 23, 2009 | D-Link DP-301U (790069251979) Print Server
DP301U COMPATIBILITY
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    Cant print from workstations
    Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
    Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
    Documents not printing
    Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
    May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    2,343 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
