A clean install has no programs left, thus the word, clean.
error One is called microsoft.
call HP, its there system not MS, ever.
never do that.(i can, but im never going to teach you that)
hp dont support windows7 on this system?
stop talking to MS and talk to HP,
HP built it not MS
Only HP has all the drivers, if you told real model number, i could look up your options.
do what they say. HP, Hp.com support.
is this a laptop/?
HP also made, Pavilion DESKTOPS. so >????
see yours here?
http://support.hp.com/us-en/products/laptops/pavilion-notebooks/
or legacy
you said Vista it must be real old
click LT then pavillion then click see yours in RETIRED? 20 are class.
http://support.hp.com/us-en/retired-products
we can not guess laptops ever.
you need this to ID what you have.
Pavilions 1000s there are.
here i made text list to show the large numbers made.
current
Pavilion 10
Pavilion 11
Pavilion 12
Pavilion 13
Pavilion 14
Pavilion 15 (expands out 46deep) endless.
Pavilion 17
Pavilion dm1
Pavilion dm3
Pavilion dm4
Pavilion dv2
Pavilion dv3
Pavilion dv4
Pavilion dv5
Pavilion dv6
Pavilion dv7
Pavilion dv8
Pavilion dv1000
Pavilion dv2000
Pavilion dv3000
Pavilion dv6000
Pavilion dv9000
Pavilion dx
Pavilion g4
Pavilion g6
Pavilion g7
Pavilion HDX
Pavilion m1
Pavilion m3
Pavilion m4
Pavilion m6
Pavilion m7
Pavilion tx
retired
Pavilion dv1000
Pavilion dv2000
Pavilion dv4000
Pavilion dv5000
Pavilion dv6000
Pavilion dv8000
Pavilion dv9000
Pavilion n
Pavilion xf
Pavilion xh
Pavilion xt
Pavilion xu
Pavilion xz
Pavilion zd
Pavilion ze
Pavilion zt
Pavilion zu
Pavilion zv
Pavilion zx
--------------------ugh!-------------------
NEXT TIME?
ASK HOW TO UPGRADE ANY HP.
ASK,, FIRST
LEAP 2ND.
AND WIN.
I PROMISE.
OH, YOUR MODEL NUMBER IS NO GOOD.
HP WOULD ASK FOR THE SERVICE TAG
SO , WHY DELAY THAT.????
YOU CAN NOT GET HELP LACKING THAT.
NOT ACCURATE HELP, EVER.
IS THAT CLEAR?
also , know that each newer windows
the PNP engine
can not support drivers on many old systems
that is is because those are old chips
and
1: they dont make them now.
2: and due to that fact no w10 drivers.
so that means if you box is old
ask what you can run on it.first.
ask HP first.
most old visa boxes are too old
to upgrade, much past w7
if at all.
there are exceptions.
learn this too.
when you upgrade to w10
its a bit smarter now.
it will keep some applications and dump half the others.
I know this for a fact,
its a new feature too.
the new OS will make folder with old dead
program files.
letting you know the bad news.
(i like this feature, one if MS best ever)
so that means if you are unhappy
you click go back to w7 or vista.
in 30 days,
thats only APPS
but drivers too will be missing
for very old chips
eg1
say a dead audio chip maker,
a dead video chip maker, like
any of these (omg endless)
https://en.wikipedia.org
/wiki/List_of_defunct_graphics_chips_and_card_companies
and defunct , wifi chip makers
the list is endless.
but not all is bad.
most w7 drivers that worked in w7 can work on w8 to 10
can, no promises...
ive done vast systems and upgrades from w95 to now.
see all pitfalls. in time.....
also Linux guy too.,
same is true each version of windows release
old dead chip makers will be a problem.
MS even publishes a list of supported chips, (each release)
and is devoid of VAST dead makers of chips
MS can not force any dead company to go back to the living, be fun to watch though. (like zombies)
lets bring back Diamond Multimedia
or S3
SOURCE: how to reinstall from the recoverydisc drive in hp laptop
You have to create the recovery disk and than you can restore the same. How to make the recovery disk is shown in the manual you received with laptop.
SOURCE: installing blu-ray drive on hp m8200n - dvds not read
Look at the back of both drives, there should be some tiny jumpers located next to where you plug the data cable in. One drive should be set to master and one drive to slave. Chances are you have both set as master. Change one to slave and your problem should go away.
SOURCE: trouble installing xp on a hp pavilion t3000
use the Windows Xp CD to format the hhd twice.
install the OS from the CD without partition.
you can always partition the hhd later.
SOURCE: Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
SOURCE: in the device manager, Device manager unknown acpi
You would have to install the ATI chipset drivers , the same can be downloaded from the site below
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3292424
Thanks
Proton
