Question about Canon PIXMA iP3600 Photo Printer
I have a canon printer pixma ip 3600, how manage the service error 6502?the printer can't be work again.
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
Posted on Jan 18, 2008
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
SOURCE: Canon Pixma IP600D - error code 6502
THANK YOU VERY MUCH FOR THE HELP. THE CANON PIXMA iP1000 SEEMS TO BE WORKING WELL. LET'S SEE HOW LONG.
GREAT FixYA Saves me from too much worrying. I have 8 printers inside the office: Canon 4, Epson1 HP 2 and 4 computers and 5 scanners.
Thank you for the email reminding me if I need help.
This is documentations time in CAFAG, Inc.
The Executive Officer - Lydia
Posted on Oct 05, 2008
SOURCE: canon pixma ip4700
This error generally means that your cartridge chips cannot be recognized. The primary causes are: Covering of the LED at the back of the chip (by ink?). Incorrect chip positioning on the cartridge.The LED on one or more of the cartridges has been damaged if removed from original cartridge.The Chips have been mixed up, if removed and replaced, the wrong Chip has gone on the wrong color. And lastly Ink is covering the cartridge chip or a sensitive area of the cartridge and preventing the LED light sensor from functioning. ( my problem)
Posted on Feb 08, 2010
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
Canon ip 4500 error code 6502
Hi,it needs new print head. The print head is not functioning right. I have the same problem, the funny thing is, a new printer cheaper than the print head and a set of ink cartridges .
Hope it helps..
Nov 06, 2010 | Canon Pixma iP4500 InkJet Printer
I have canon pixma proi 9000 I keep getting an error 6502 I have turned the printer of and on, cleaned all the cartridge heads, unplugged the print and on again I still get the 6502 error
Hello
Follow the below steps in order to clear the error:
1.With printer OFF press and hold resume
2.while holding it down push and hold Power button
3.Release resume whilst still holding down power, the light should be green (not flashing)
4.Push resume once (orange) twice (Green)and a third time (orange)
5.release power button.
6.Then power it off and on again after it's finished making any noises and settled down.
Good luck.
Aug 12, 2010 | Canon PIXMA Pro9000 Printer
Canon pixma ip4300 Stoped working, light flashes 19 times and error code 6502 displayed on screen Help please?
Hello
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Oct 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer service error 6502
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Oct 03, 2008 | Office Equipment & Supplies
Canon IP4500 service error code 6502
canon pixma 4500 service error 6502
Jul 15, 2008 | Office Equipment & Supplies
Canon ip3500
I have Printer Canon Pixma IP3500 has been error 6502.
What is solution? Please help me.
Jun 09, 2008 | Canon I990 InkJet Photo Printer
Canon iP 3300 printer service error 6502
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Canon PIXMA iP3600 Photo Printer Logo
386 people viewed this question
old marine
old marine
