Question about Frigidaire FRS26ZSG
Frigidaire FRS6LE4FW5 Everything in my freezer is thawing out. Ice is melting. Sounds like its all still running fine though. please...any suggestions?
  • 3 Answers
Lets see, u must be a *******!
Posted on Jun 04, 2008
Tip
How to fix a leak inside a refrigerator
Turn off the refrigerator. Remove the rear panel and floor cover from the freezer. You will see a lot of ice covering everything. Remove/thaw this ice.
In the back of the freezer, under the coils is a drain. When the defroster runs and melts the ice on the coils, the water is supposed to run down the drain to a pan where it is evaporated by a fan under the refrigerator. Often, this drain freezes shut. Then, the water has no place to go but though the vent into the refrigerator.
Melt the ice in this drain with a hair dryer or small quantities of hot water. You will know the drain is clear when the water level suddenly drops. Finish drying everything in the freezer and replace the panels.
Now, you will no longer have water dripping inside your refrigerator.
on Feb 06, 2010 | Refrigerators
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Have a GE refrigerator side by side came home electronic display was out, food compartment was warm, ice melted in freezer, food thawing but lights were on . What's happening no motor sounds run
Without your model number I can't give you a part number but I can tell you the part. GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
May 01, 2012 | GE Refrigerators
I have a Frigidaire Model FRT18s6aws year model 06. It will thaw an d refreeze food and ice on and off. When it thaws it seems the fan is working fine and is triing to get cold and the next day everything...
When your unit thaws - do you hear the compressor kicking on at the start of a cycle? If not, maybe the compressor relay it hanging up somehow. Or the compessor capacitor is malfunctioning. It is NOT a compressor problem though.
If you are capable of getting to the defrost heater circuit, you should check the defrost thermostat and timer (if there is not ice build up behind the panel. If the defrost circuit is active too long it could cause that condition - but you defrost heater is not the problem unless there is an ice build up.
Jun 12, 2011 | Frigidaire FRT18S6AW Top Freezer...
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire professional series. Feels cool inside but the air is not circulating and everything is starting to thaw out, ice is melting.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Refrigerators
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
94 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
