Question about Kenwood KDC-MP235 CD Player
Can't get the auxillary to play or even come up
Can't get the auxillary to show up. Standby, CD, Tuner all come up but not auxillary.
  • 3 more comments
  • millertime80 May 31, 2008
    I cannot even get the auxillary to come up. My ipod player will not play thru the rca jack at all.
  • huey78 Jun 13, 2008
    my aux setting does not come up only tuner cd and standby
  • Crispychiken Jul 11, 2008
    Is the AUX option only for IPOD? I tried the suggested solution but its not working for me. Please help. Im using a AUX cable directly from my Sony Mp3 player to the AUX on the deck.
  • dragonsfire7 Jul 12, 2008
    Cannot get AUX to show at all.
  • dmia06 Dec 26, 2008
    ipod i put trouble
When its on standby hold the menu button and then use the right nob to change aux on then press menu again and src untill aux shows. hope this helps
Posted on Jun 23, 2008
Take off the face and hit the reset button.
Posted on Jul 04, 2012
2 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: using the auxillary setting
You'll need to turn the auxiliary function on in the setup menu. Press Source to put the unit in Standby, then press and hold the Menu button for at least 1 second. Press the control switch toward AM or FM until the AUX setting comes up, then press the control switch toward <<< or >>> to change the setting to ON. You can download a user's manual here: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Posted on Jun 24, 2007
CAR RDIO MP3/CD. ALPINE 9852. SECOND HAND CAR HAS RADIO RECEIVER AND PROVISION AND JACK FOR ATTACHMENT. NO MANUAL. WHERE CAN I OBTAIN A MANUAL AND WHAT DO I NEED TO PLAY DISCS AND MP3?. REGARDS GEOFF PEACH
go to alpine website and you can pull up a manual from the archives and print it out. Umm as far as playing disks you just flip the face down and load a disk into it and it will play it . you will probably have to have an mp3 cord plugged into it to access the "auxillary" mode under the sources button. But other than that yea just hit the source button and it should switch between tuner cd and aux to play whatever you need it to play
Jan 31, 2010 | Alpine CDE-9852 CD Player
Aux input. Kenwood ecelon dpx-701
You have to go into the menu and turn it back on. It is in the menu under "built in aux" and just switch it to on.
Feb 27, 2009 | Kenwood Excelon DPX-701
No CD
The normal source selections for this model when the SRC button is pressed are: TUNER, CD and STANDBY.
If there is no CD inside the tray, or if it is dirty, unreadable, inverted or damaged, then the CD source option will not display at all.
If the there is a known good CD placed properly inside the tray and the CD source will still not show as a source selection, you may need to RESET the unit. The reset button is near mid bottom. This will also erase all settings, memory and tuner presets.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Kenwood KDC-3027A CD Player
KDC-MP522
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 07, 2007 | Kenwood Sirius KDC-MP522 CD Player
Cannot select different sources
There is an easy solution for this, put a cd into the stereo and then go through your sources, it will now show standby, tuner, cd.
Aug 08, 2007 | Kenwood KDC-MP335 CD Player
Auxillary option not available in menu
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Using the auxillary setting
Jun 23, 2007 | Kenwood KDC-MP205 CD Player
Help!!
if you have a amplifier to it you might want to check your remote wire there is two of them they are blue check and see if its connected to the one that says amp not antena remote.i think that that is you problem
Nov 22, 2006 | Kenwood KDC-MP628 CD Player
Kenwood KDC-MP235 CD Player Logo
416 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
