Question about Frigidaire Kitchen Ranges
Frigidaire electri-clean oven overheats greatly. no temperature control
Frigidaire electri- clean oven heats to 500 degrees no matter what the temperature control is set to.  What is happening ?
Posted on Nov 08, 2008
My oven is keep beeping and I can't cancel it
Good Morning Friend, that's a great question!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 13, 2014 | Frigidaire Ovens
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
F1 beeping
Hi Andrew! Sounds like the unit is having a runaway temperature concern. F1 or F10 indicates the temperature has become too high for the unit. A professional is required to check the sensor probe in the oven. If the oven is overheating, disconnect its power. If oven continues to overheat when the power is reapplied, a technician will need to replace the electronic oven control (EOC).
Sep 04, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I put my Frigidaire Electrolux oven in cleaning mode an hour ago. It is now beeping non stop with "F1 Err" on the screen. Nothing I push seems to work
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement.
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional detail
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidaire electri-clean stove/over. the oven lower burner seemed to have burned out, can this be replaced?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Frigidaire FEF352 Electric Kitchen Range
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Oven Temperature rises above setting
You may or may not see the error code.
The temp probe is less expensive and is most likely your problem.
If you choose to replace it and the problem remians your ERC will have to be replaced.
ERC electronic range control
Mar 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Jun 11, 2008 | Frigidaire Ovens
Kitchen Ranges Logo
430 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
