Question about Casio Exilim EXZ75 Digital Camera
Set up settings won't stick after camera is turned off
Everytime I turn off my camera and turn it back on, I have to go through the set up again of setting the date & time, country, etc. Other than that, the camera works fine. Any ideas what the problem is?
  • Anonymous Mar 25, 2009
    SET UP NOT STICKING AFTER CAMERA IS TURNED OFF WHAT TO DO
  • 477 Answers
Yes on the ex-z75 Casio camera there is a internal battery right under the front cover by the speaker wires this battery is a 3.6 volt battery that is soldered on the board. the only what is to make a make shift battery pack and solder it on to the prongs. I do this with out any guarantee that because it is not factory default and they do not sell the battery to any one. most of the time they will tell you the main board has to be replaced. if the main board has to be replaced it is 85.00 plus shipping from my shop but if soldering a 3.6 battery pack works then it would be 40.00 to replace the battery.
Posted on May 29, 2008
Sony Bravia LCD tv model KDL40S4100 won't hold settings.
What you've heard is right. This is a main system control memory IC fault itself.
Jun 19, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
Hi, I change the memory stick for a 4GB,and now every time I turn on my camera I need to set the clock(but it won't set!!).Then I put back the 2GB memory stick and I still have the same problem.
The memory card for a digital camera is only used to store pictures. The problem with your camera not storing the date correctly is most likely a battery issue. If you let the camera battery completely drain, it will reset to factory settings. If this is not the problem, I would suggest calling the company's tech support line, as they will be able to help you track down the problem.
Good Luck!
John Vickers
Sep 18, 2011 | Cameras
Power on Set up
Somewhere on the camera it will list and ask which language you want, check english on the list. Good Luck
Apr 27, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
The date and time start up appears everytime i turn on.
Set the date and time at least once... if it still keeps coming up when you change the batteries the back up battery/capacitor has failed... my old kodak does that so i know the frustration but it's still a good camera
Robert
Jan 22, 2009 | Casio Exilim EX-Z77 Digital Camera
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Will not focus
First Send me your camera's model (Brand Name)
Some digital and analog camera in these days has features to manualy set the focus in our wish.
Try to disable this feature. And try not to poke or push the lens of the camera. By doing this you may destroy the lens.
And try to reformet the mem stick + try to reset the camera.
(Everything will be resetted, "it will be as if you have a new camera")
Feb 03, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
469 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
