Question about Casio Cassiopeia EM-500 Pocket PC
I have a Casio Cassiopeia EM-500 Pocket PC. The screen has gone so dark that it's barely readable with a magnifying glass even with the brightness and contrast settings at their lightest. Sometimes the screen will get bright again (maybe every couple of days) for a while, but the colors are off compared to before. Everything else on the unit is working. The main and backup batteries are both fully charged. Please help!!! Thank you so much!!! Vivian
vega
  • 551 Answers
SOURCE: Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Posted on Sep 05, 2005
vega
  • 551 Answers
SOURCE: EM-500 Conection Problem
There have been issues with Em-500's USB adapter in the cradle. If your device is still within warranty period I suggest you contact Casio to upgrade the pcb in the cradle to solve your problems. I have successfully connected EM-500 with upgraded cradle to XP & ActiveSynch 3.1.
Posted on Sep 06, 2005
vega
  • 551 Answers
SOURCE: e-125 dark screen
Have you checked the screen control settings? I had the same problem on a E-125, and it turned out that I had a screen backlight auto shutdown time that was very short - this could be the easy solution - simply adjust the auto dimming timer in the settings control. Controls setttings is a pull down menu under the "Start" button at top left corner of screen. If it's not that - then back to Casio? Good luck.
vega
  • 551 Answers
SOURCE: Overclocking em-500
1) Back up your device since we will be removing both batteries from your PocketPC. 2)Remove all 5 screws (4 in the back and one underneath the rubbery grip sticker on the side). NOTE: Be very careful with the sticker on the side. I just pried it up with my finger nail to get it started, but the adhesive part split off from the rubbery grip. I then had to pry up the adhesive part from the side of my EM-500. I got them back together in the end, so no harm done - just something to look out for.
  • 4 Answers
SOURCE: Cassiopeia E-125 getting it charged
to need a charger.
Posted on Jan 01, 2008
I am missing my USB cable for the Cassiopeia Em-500. Where can I get one?
There is a casio supply store in NY that might have it. there number is 1-800-345-0537. Their name is American Perfit.
Hope this helps!!!
Sep 20, 2009 | Casio Cassiopeia EM-500 Pocket PC
Overclocking em-500
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio em-500 deleting mail programs!!!
I believe they are in unit's ROM, which is non-reprogrammable. Hence, you won't be able to delete anything from there. On the positive side, they don't occupy your main memory, so there's really no harm in letting them dwell in your PDA. :)
Casio EM 500 + Nokia 7650
well there is a solution but im not too sure, but it is to get a cable that conects to ur phone and ur pda..that should work it not....there may be something wrong
E-125 dark screen
Bingo! You hit the problem on the head. If you can still see an image, albeit extremely faint, and the Casio is still working, i.e. playing an mp3 file or whatever, then you definitely have a problem with the backlight. More times than not, this is either a daughterboard problem or a connection problem (rarely have I seen an actual bulb failure though it can happen). One of the more common causes is the tiny ribbon cable connector on the daughterboard. You might try to disassemble it, clean the contacts of the ribbon and reassemble the device. I've also heard of people squeezing in the side of the case to temporarily effect repairs...this is normally more ominous.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
MMC/SD Cards
In most cases they are interchangeable except for the security feature which you don't need for storage on your EM-500. SD cards are faster in read write department as also they cost more due to security featurtes built in. In Casio cameras Casio recommends SD cards but I have been using MMC cards very successfully.
Upgrade Activesync and the PC's USB driver. Then you should be OK once you upgrade Activesync to V3.6 and then get the latest USB driver for your system. Good luck
Connecting to a Linux machine
Have you ever heard of wine? You can install wine for free and see if the program that allows you to interface the device to a PC will work. There also could be some linux programs that will allow you to connect your pocket PC to your PC.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM500 replace touchscreen
They are in fact very easy to replace if you: 1. Are very careful not to damage the other parts 2. Can find a replacement Understand that the screen is actually two different components, first there is the digitizer which is the part that senses your touching the stylus part. It is a clear glass plate that sits in front of the color lcd unit (the other part). If only the glass is broken, then replacing the digitizer is a cinch. If I remember correctly, the digitizer on the EM-500 is the same as the digitizer as on an E-125. You'll have to check to be sure though. Anyway, it is not too hard, just needs steady, careful hands...and it helps to have a little experience taking these things apart...
Broken screen
Replacement of the digitizer, if the lcd is still intact. If that is damaged as well...sell it for parts, or get parts from another. The EM500 and E125 share the same lcd/digitizer.
Casio Cassiopeia EM-500 Pocket PC Logo
54 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
