Question about Whirlpool 24 in. Portable Dishwasher Dishwasher
I need the steps to change the hose assembly on my Whirlpool portable dishwasher. When I got it someone had cut the sink connections off so my son connected it to the water and drain with my washing machine which was in the kitchen. However, I have moved and want to use it as portable. I purchased the new hose assembly for the sink faucet, I just need instructions on how to take the dishwasher apart and connect the new hoses.....HELP PLEASE!
    Problem Solver:
  • 14 Answers
Hi, I found this video on You Tube, regardless of manufacturer, the procedure is the same. Click on the link below. GE WD24X10066 UNICOUPLE ASM PartSelect
Posted on Jun 26, 2017
  • 641 Answers
SOURCE: Dishwasher isn't draining
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
Posted on May 29, 2006
elhomspam
  • 58 Answers
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Posted on May 02, 2008
jtbjtb
  • 135 Answers
SOURCE: Water not draining whirlpool quiet partner ii
Remove the drain line where it hooks into the disposal. See if the plug, which must be removed to let water thru, is still in there. I ran into this on a service call a few years back. Removed to plug and voila! Hope this helps!
Posted on Jan 13, 2009
  • 93 Answers
SOURCE: Convert a whirlpool portable dishwasher to undercounter
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Posted on Dec 30, 2009
  • 311 Answers
SOURCE: When the dishwasher is in rinse cycle the water
This means your drain is backing up. You can try removing the J-trap under the sink and clearing it its the U shaped pipe. If this does not correct your problem you will need to call a plumbing co to have them out to snake it out. Hope this helps. MJ
Posted on Apr 12, 2010
Can the dishwasher hose intake be rotated so that the hose does not have to loop around the disposal?
You can cut off the dishwasher hose so it is shorter, but that might not give correct end for connecting to drain tailpiece. See if end of dishwasher hose has built-in fitting.
They sell universal connections that fit both the dishwasher hose and the drain tailpiece... but check what is available at hardware before cutting off dishwasher hose.
The drain tailpiece can be taken apart and then rotated so dishwasher hose can come from different direction. This requires removal of p-trap, and cleaning of each part before reassembly.
If this is double sink, the disposal can be moved to other side, and sink basket with tailpiece move to other side.
Following link has step by step tips for taking apart P-trap and reassembling tubular drain pipes so they don't leak: and installing disposal if you switch sides on double sink
http://waterheatertimer.org/How-to-install-vent-under-sink.html#apart
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2014 | Electrical Supplies
Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Jul 25, 2012 | Whirlpool Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool gold and there is water in the bottom after the cycle. i cleaned everything out and didn't see any blockage.
the drain hose maybe clogged it connects to the garbage disposal or the air gap at under the sink. you can get a wet dry vac and **** it out . or if the hose is just laying under the sink on the bottom of the cabinet you need a loop put in it. just attach it to the top of the sink some where and leave slack after the attached location toward the sink.
Nov 17, 2010 | Whirlpool DU930 Built-in Dishwasher
My dishwasher isn't draining
Check the drain hose all the way from the dishwasher exit hole through the air gap and into the sink connection. This is a common problem when a dishwasher will not drain. You will need to dis-assemble the air-gap by removing the cover and unscrewing the drain cap to check for particulate matter. Make sure you note the oreientation of the cap when you remove it as it will only fit one way. It is best if you remove the hoses and check all of the drain holes for obstructions. Dishwasher to sink connection.
Thanks for using FixYa.
Kelly
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Plastic hose disconnect Frigidaire dishwasher - sink side
Most dishwashers connect to the garbage disposal and just have that barbed connection that it clamps onto with a hose clamp, unless that actual connector itself broke off (which wouldn't be pressure related, that would mean someone hit something against it breakin it) You should be able to just use a screwedriver and tighten the hose with the clamp back onto the garbage disposal.
If the plastic connector did break off then you will have to buy a new garbage disposal and replace the whole thing. Which is just a little heavy and time consuming but not all that difficult to do.
Or if it did break off, and your handy with glue, then you could try using a waterproof glue to glue it back on?
Also just a warning, if you try to use the sink, make sure you have a bucket underneath the garbage disposal as water will then leak out the hole where the dishwasher drainage tube was connected until you get it fixed.
Jul 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Dishwasher
I would put the dishwasher on its back so you can see underneath to check the fill and drain hose to make sure there not damaged in any way to cause it to leak. if it all looks good under there return it upright and remove the front lower kick panel grab a flashlight and start the dishwasher. you shoud be able to see a leak and where it is comming from. its possible it could be from the hose the inlet valve the pump and motor assembly or the plastic tub itself. good luck
Aug 04, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Whirlpool 24 in. Portable Dishwasher Dishwasher Logo
70 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
