Question about Garden
I have a garden sub JDS01-021patio heater. Pilot light will stay on whilst depressing knob but stops when I release knob. My guess is that it needs a new thermal switch??? Where can I get one? Thanks Toby
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
This is a sure sign of a bad thermocouple or a dirty mating area where the thermocouple terminates at the gas valve.
Try this first.
Disconnect the thermocouple at the gas valve by removing the thermocoup0le mating nut and thoroughly clean the mating surfaces. The reinstall the thermocouple nut firmly. Any corrosion or dirt in this area can cause the thermocouple to no pass the milli-volt signal to the gas valve. Test the pilot light after cleaning.
If you still have the problem after doing the above remove the thermocouple and carry it to any well know appliance parts supply OR home heating and air conditioning supply and purchase a thermocouple. The thermocouples are not brand specific. What you need to make sure of is that the length and mounting hardware are the same.
I am pretty sure this is all you need to do.
Thanks for choosing FixYa.
Kelly
Posted on Oct 08, 2010
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Village series QV32B pilot light won't stay lit
Classic symptom of a malfunctioning thermocouple. When you press the knob, you force the gas valve open so gas will flow. The function of the thermocouple is to confirm that the pilot is lit and allow gas to continue to flow when you release the valve. A new thermocouple is not that expensive. Good luck!
Jan 05, 2015 | Heating & Cooling
Heater pilot light will not stay lit
The thermocouple is either too far from the pilot flame or is bad.
Feb 26, 2014 | Garden Treasures Patio Heaters
40,000 btu Charmglo patio heater, brand new, pilot light stays lit as long as you keep the knob depressed. As soon as you release the knob, and turn it to the high position, the pilot goes out! Please...
There is a thermocouple that detects that there is a pilot flame so that main gas won't come on unless there is a pilot. That thermocouple is faulty. These are available from a plumbing supply house. The thermocouple will be attached right in the flame from the pilot and connects back into the gas valve.
Dec 24, 2010 | Garden
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Need to light pilot cozy brand gas wall heater
Is there a "Pilot" marking on the knob? Try moving the knob 1/2 way between on and off and depress the knob. If you are in the correct location, the knob should depress in about 3/8 of an inch. Once you find the location where you can depress the knob, there should be a red sparker button that you can snap to light the pilot. Depress the pilot knob and snap the button a few times. There may be a small viewing port at the pilot. It may be covered by a small metal shield held on by a thumb screw. You can remove the shield to view the flame. OK so now you can depress the pilot knob, snap the sparker, look for the flame while still holding down the pilot knob and count to 30. Slowly release the pilot knob and check to see if the pilot is still on. Once it stays lit, rotate the knob to the "ON" position.
Jan 04, 2010 | Cozy Heating & Cooling
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Piolit light on a raypark gemini spa heater
take off front door instructions are posted on it.if not, turn gas valve to pilot,depress,place flame in front of pilot tube,should **** flame in and ignite pilot,when it lights,continue to hold knob down for 30secs.,release ,if pilot stays on,turn to "on" position. you're" ready to go!!
Apr 08, 2009 | Pool & Spa
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
