Question about Acer 22" X223w LCD Monitor
Vertical lines start appearing in my x233h lcd monitor..is there a way to fix my lcd monitor?
  • 11,361 Answers
Yiu can try reseating the T-CON board connector on the back of the LCD panel first, but more likely you have failing LCD panel due to the TFT driving circuits which new panel will be needed.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 08, 2010
I have one vertical green line on my Acer 4637z laptop. How do I fix this?
That is the LCD failingn it will get more lines as time goes by. You can try resating the ribbon cable on the T-CON board mounting on the back of LCD panel.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Mar 02, 2011 | Acer X233H 23 in. LCD TV
There is a very thin vertical red line on my screen that has appeared this morning and is is there whenever the screen is on, no matter what program I am in.
That problem is called Vertical Problem in your TV.It might be cold solder or loose connection of board in vertical section.Need for resolder or if not work after resoldering.The vertical ic is the problem it is deffective.
Oct 06, 2010 | Acer X233H 23 in. LCD TV
Green vertical line down right side of screen probably 1 pixel in width. It showed up after a night on standby as soon as it came on
You TFT drivers are failing in your LCD panel, not much you can do, you will get more lines as time goes by, more transistor for driving the TFT will fail.
Jun 06, 2010 | Acer X233H 23" Monitor
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
May 19, 2010 | Westinghouse L1975NW Monitor
Vertical lines on lcd how can i fix it works perfect with ext monitor and i did bios update and it help some?
Restart the Computer and access the BIOS and check if the vertical lines are visible. If the vertical lines are visible in the BIOS then the issue is with the LCD screen itself and may require service. This is confirmed when an external monitor works fine. If the issue is related to the video card of the Computer then the lines should also appear on the external monitor which is not the case.
Oct 24, 2009 | Dell Latitude C600 Lcd LCD Display
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Green vertical line on LCD screen
Is this on a monitor or on a laptop LCD display?
Most of the time it is due to a hardware issue like a video card or the screen itself.
When does the line appear?
A. Is it there even with the monitor or laptop turned off?
B. Is it there during the OS logo / boot screen or does it appear after the OS loads?
C. If it is a monitor, with your system turned off go into the menu of the monitor by using the buttons on the front. Is the line there?
What you can do to try and fix it is.
1. Make sure you have all the latest drivers for your video card.
2. Change the resolution of the screen.
3. Change the frequency of the monitor.
If these do not fix your issue you may want to look at getting or borrowing a video card and replacing it if this system is a desktop. If this system is a laptop and the above does not fix the issue your best bet would be to put up with it or buy a new laptop to be honest.
Jun 19, 2009 | Acer 22" X223w LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Acer 22" X223w LCD Monitor Logo
321 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
