Question about Kensington Televison & Video
When I click the red pointer light, the computer bell rings. How can I stop that?
  • 10,515 Answers
Kindly mention the make and model of the product.
Kindly explain the problem in detail.
Thanks!!
Posted on Oct 08, 2010
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
Mar 24, 2018 | New Home Security
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
Belling 665 halogen ring faulty
You would need to study a circuit diagram for the stove to figure out where the fault is probably to be found and how it works or alternatively take it apart and follow the wires making notes as you go.
It is true, obsolescence and unreliability and a shorter lifespan is often built in to appliances and other things. Part of the reason is sensible designs using quality parts and engineering are too expensive and so good designs are production engineered (corners are cut) to save money, usually introducing problems and unwelcome "compromises". Often sophisticating the design using cheaper methods are used to overcome problems caused by production engineering.
One of the big problems with stuff designed to have a shorter life is the replacement parts needed to make them last a bit longer are usually priced not to sell.
Apr 05, 2017 | Kitchen Ranges
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
A yellow shield symbol keeps flashing on my computer, how do i stop this i have clicked on the red cross but it keeps coming back
scroll to bottom of screen right click in taskbar select task manager applications if you see something running that should not be running select end now
hope this helps
Oct 24, 2011 | Packard Bell (168143) Computer Speakers
Hi my laptop developed a strange problem. I formatted the system drive and installed a fresh copy of windows 7 ultimate sp1. now at the boot up the laptop makes loud annoying ringing bell sound for a few...
Is the "ringing bell" sound a series of beeps? A computer will have beep codes at start up for the user to identify system errors. Count the beeps, one long and 2 short or 3 short beeps or one continuous beep, etc. Then you can search to find what that specific beep code stands for. As for the the touchpad you may need to go into the system properties, right click on my computer, click properties and then click device manager on right. Click the "+" next to mice and other pointing devices. Double click on the touchpad device and then the driver tab. Click update driver and see if it finds a better driver. Or do a windows update. Sometimes the problem can be fixed there. Lastly, and oddly enough, try to take out your battery when the power cord is plugged in. I have seen cases where a bad battery can cause problems with the touchpad and keyboard. I hope one of these helps!
Sep 24, 2011 | Computers & Internet
While driving a bell ringing happens when i make a right turn. sometimes the bell rings continually while i'm driving. what the problem?
Sounds silly but this is how i fixed my bell ringing. !st the ringing is the alarm when you open the door and the key is in the ignition or the car is running. I found the push switches that are on the side of the car and are operated when the door is shut have become loose. All you need to do is tighten them up a bit and the bell ringing will stop. When you make your right turn you probably push a bit on the door and that helps open the switch more. The switches are the contact switches that turn on the light as well as the warning sensors for open door. See if your dome lights flicker a bit as well.
Mar 05, 2010 | Hyundai Motor 2004 Sonata
The ignition bell wont stop ringing
You need to unplug the door harness one at a time to locate which door is causing the problem. Once the door is located, you can replace the switch which is located on the lock mechanism.
Sep 29, 2009 | 1994 Ford Ranger Supercab
Car door bell won't stop ringing.
is there any type of check engine light on or any type of warning light is the sound of the bell the same bell sound when you open your door or seatbelt warning
Aug 28, 2008 | 1997 Plymouth Neon
Bell on ignition switch does not stop ringing on 1999 Dodge Caravan.
Locate it by sound & pull it out, and replace it. probably stuck relay inside it.
Aug 03, 2008 | 1999 Dodge Caravan
Televison & Video Logo
160 people viewed this question
Top Kensington Televison & Video Experts
Squalidstuff
Squalidstuff
Level 1 Expert
Lawrence Oravetz
Are you a Kensington Televison and Video Expert? Answer questions, earn points and help others
