FixYa.com
Tags:
Printers
Generic problem for all Ricoh Printers
Ricoh ap 3850c error code
posted by edhogg on May 29, 2008
ricoh ap 3850c error code 552
Comment by edhogg, posted on May 29, 2008
I just replaced the entire fuser unit and the fuser oil unit. Do I need to do a reset, and, if so, how do I do that? Thanks
Comment by edhogg, posted on Jun 02, 2008
Unfortunately That sequence didn't work to get me in service mode. There are the following buttons: Online, Menu, Cancel, Enter, left and right arrows and up/down arrows.
Thank you for your help..
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
Inky
Rank:Wiz Wiz
Rating: 85%, 639 votes
Check the fuser thermistor and transfer roller continuity.
Comment by Inky, posted on May 30, 2008
You need to enter service mode to reset the SC CODE:
Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
Use the keys to move down to service mode 5 - SP5-XXX (MODE) and press ENTER
Search through to 810 - SC RESET, Press ENTER and a reset will be executed. Once reset, power off the unit and back on.
PLEASE do not alter anything else within the service mode as damage may occur.
Rating Locked! (?) edhogg has rated this solution as FixYa!
This Problem Also Relates To: Ricoh Aficio CL2000N Laser Printer Ricoh Aficio 1515MF All-In-One Laser Printer Ricoh Aficio 650 Laser Printer Ricoh Aficio 220 Laser Printer Ricoh Aficio G7500 Printer Ricoh Aficio SP C210SF Printer Ricoh (R) Aficio CL3000 Color Laser Printer
Can you Help with these Printers problems?
Printers
I want to print envelopes
I want to print envelopes in a... Answer This...
Printers
says i'm out of color
says i'm out of color ink. I... Answer This...
Printers
error message: print head not
error message: print head not... Answer This...
HP LaserJet 3330 All-In-One Printer
Fax Line Programing for the...
I just switched from a... Answer This...
HP OfficeJet 300 All-In-One InkJet Printer
will not print received fax
Shows receiving fax by page,... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
