Question about Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC 25 Dyson Ball animal. The bottom brush is not rotating. I detached as and reattached as the manual suggested. Help Thank you very much
  • 377 Answers
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Posted on Oct 08, 2010
How to remove ball from Dyson dc 25 Animal ?
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
Feb 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dc dyson 24 free repair maule
    About 1,100 results (0.84 seconds) Search Results
      ? 1:55
      https://www.youtube.com/watch?v=akGLQ7UbctY
      Sep 29, 2011 - Uploaded by AskDyson
      DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
      How to fix your Dyson Vacuum Cleaner when it loses ...
      ? 7:45
      https://www.youtube.com/watch?v=0vd3ldLXgI4
      Apr 16, 2013 - Uploaded by Chuck Fresh
      How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
      [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
    Jan 28, 2016 | Dyson Vacuums
    My dyson dc 25 sparks near the rotator roller attachment, what can I do?
    Hi Cindy, it's Jack at Dyson.
    If you can see sparking coming from inside the cleaner head, please do not continue to use your machine until we can help resolve this. It's likely the cleaner head will need to be replaced - once we've taken a few further details, we'll be able to confirm if this is covered under your Dyson parts and labour guarantee.
    At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
    Dec 16, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
    Dyson 25
    www.dyson.com/support.aspx
    Jul 08, 2014 | Dyson Dc 25 Animal
    BRUSH NOT SPINNING ON A DYSON DC44 ANIMAL
    Hi Veronica,
    Thank you for reaching out. I am sorry to hear your brush bar will not rotate. In light of the detail you provided regarding the spindle there are a few checks we need to complete in order to determine the best solution. Please call our Helpline to speak with an expert.
    US - 1-866-693-9766 or UK - 0800 298 0298
    Best wishes,
    Jessica
    Dec 17, 2013 | Dyson Animal Bagless Cordless Hand Vacuum,...
    DC41 ANIMAL
    Hi Ashley, it's Jack at Dyson.
    I'm sorry to hear you've had difficulty with your DC41 Animal's brush bar. Although I note you've already tried resetting it, I would encourage you to try again - please make sure that you've reclined the machine into the vacuuming position as the brush bar will never rotate when the machine is standing upright. Try pressing the silver brush control switch (next to the red on/off switch) twice while the machine is turned on and reclined.
    If you do need further help after trying this, please contact us directly so we can confirm if we're able to help under the terms of your DC41 Animal's 5-year warranty. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    Jul 21, 2013 | Dyson Dc 41 Ball
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    716 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
