Question about Ovens
Looking for a manual for a Stile ( Milano) Oven
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Need User Manual Kuppersbusch Okotherm Double Oven
The age of the oven may make it difficult or impossible to find the information you are looking for.
Jul 08, 2014 | Kuppersbusch Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
Flavel milano 60 manual
Keep in mind that Flavel Ovens are built by Leisure CP. This link could helpfull: upl/26348-Range60Leaflet.pdf
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 17, 2011 | Ovens
Hi i have purchased a milano 60cm fan forced wall oven. the electrician putting in a new circuit needs to know how many amps 15A or 20A.. Thanks Tony
Sorry but if he is an electrician he should know what to do! The new wall oven will have a sticker on it with the kilowatt rating. The kilowatt rating is used to calculate the current it will draw. This calculation is dependant on your voltage supply. Once this is worked out it will determine circuit size. If your electrician can't work this out you need to find a new electrician.
Mar 01, 2011 | Ovens
Hi i have a oven that says Bassano on it i have worked out it is a milano oven but can't find a user guide or manual for it and i need one or just to know what the knobs mean
hi
i think it is, grill, fan force, light/oven you need the timer on as it won't work on the first 15min and will cut out at 15min left so always add 15min to the desired cooking time
good luck
Jun 22, 2010 | Ovens
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
Sep 29, 2009 | Neff U1721 Double circotherm Electric Oven
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Oven JEP27WOK3WW
sll I am looking for is a manual to show how the oven works??
the oven is in good shape just need to know how to use the automatic part of it
Jan 25, 2009 | GE Ovens
Ovens Logo
157 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
