Question about Rancilio SILVIAespresso&cappuccino machine
How do you charge and install the in-tank water softener for the Rancilio Silvia? It came with no packaging or instructions of any kind.
    Champion:
  • 248 Answers
Web search-Rancilio silviaesprsso&cappuccino machine manual-click on 2nd site listed
Posted on Oct 08, 2010
What is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
Hi, I purchased Rancilio Silvia v3. I have overflow of water in water tank. What happens and how can I fix? Thank you.
There is a max fill line mark on the side of the water tank. Fill the water to there or less. Do not fill the water any higher than this line or water will spill out the side where the water inlet hoses run. Also make sure that the tank is not cracked and leaking water.
Apr 26, 2011 | Rancilio Silvia Espresso Machine
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
I am trying to remove my old Rancilio Silvia Group Head Gasket to install new one. It is rock hard. Any solutions for getting the old one out of place?
If you don't change it regularly it can be very hard. I've had to empty the machine, turn it upside down and chisel it out. I recommend a scratch awl and a hammer. hammer the awl in at an angle then pry it out. If the gasket breaks make sure you get all of the pieces out before installing the new one. Soak the new gasket in very hot water to help soften it so that it installs easier. Good luck.
Nov 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Manual for Rancilio Silvia V3 (two water supply tubes - why ? )
Hi
The second one is your relief valve return water line. It just sets in the tank. Doesn't go anywhere.
Dec 09, 2009 | Rancilio Coffee Makers & Espresso Machines
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Sylvia not drawing water
Let's start simple.
Is it plumbed in? Is the water valve to it open?
Some also have internal valves under the drip tray.
Is there a filter or softener between the wall and the machine? Could me clogged, mis-installed or faulty.
Does the pump run?
Sep 09, 2006 | Rancilio Silvia Espresso Machine
Rancilio SILVIAespresso&cappuccino machine Logo
116 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
