Question about Sony MHC-GX450 CD Shelf System
After hooking it up to my television, the stereo shuts off after a couple of seconds or usually a loud noise through it.. i have it hooked up with different speakers, but i don't think that's the problem. this happened before, but it stopped and have been using my stereo for a couple of years with no problems. what can i do to fix it?
  • Sony Master
  • 3,247 Answers
I am curious to understand what connections have you got in place with the TV. Do you actually hear the TV sound before the Stereo shuts off?
Are you convinced the problem is not on the TV end? I am assuming you have got a manual for this unit. If not you can check it out from here.
Posted on Oct 08, 2010
Wanting to hook up a sound bar to TV model
The cheapest way of connecting your flat screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 10, 2014 | Televison & Video
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 | Music
Model M61WH185 turn on then shuts back off
it means that you need to take it in or you have somthing hooked up wrong
Nov 02, 2011 | Televison & Video
I am wondering, I would like to hook up a very small pair of speakers to a ts3260c magnavox television, there are out puts on the back that are rca connections. i was wondering if when i plug in rca...
They will stay on if you are just hooking up the speakers. If you want the TV speakers to shut off, use a stereo system or something to switch audio inputs.
Jun 02, 2011 | Philips Magnavox TS3260C 32" TV
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Monitor issue
Hi...there,
lt's seems you got a busted backlight inverter. You can try to repaired by replacing a couple of faulty capacitors. Good luck!
Dec 05, 2008 | Computers & Internet
Sound
if your tv has a headphone jack and your truck has a cassette player, they make an adapter in the shape of a cassette with a wire running out of it and a small jack that will hook into the tv and you should get sound out of your truck stereo. if no cassette player, then they also make an fm transmitter that will hook into the tv and then you tune your fm radio to the frequncy required. radio shack or some place like it usually carries things like this.
Apr 05, 2008 | Sansui COM311AD 13 in. Combo
Stereo/mono on iLo 42 screen tv
I have encountered the same problem. I have looked through the menu at least a hundred times to find an answer, but the only thing that I have been able to come up with is to push the MTS button on the remote.
Mar 12, 2007 | iLO 2600 Television
Excessive voltage coming from television
there are 2 probable cause,...flyback transformer leak out and ur power supply goes high- v.not 4 to fix it too risky..both of this cost much..
Feb 24, 2007 | Samsung TXP3275H 32" TV
Sony MHC-GX450 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
