Question about HP w1907 LCD Monitor
Trying to connect Lenovo IdeaCentre desktop to HP w1907, monitor keeps popping up the message like " no input signal' on VGA or DVI, DVI is always checked as default. Then going to sleep right away. Push button on Menu, no response. How do I change the default to VGA with VGA cable connected. Tried to connect to the previous HP computer to change menu to VGA setting and saved, but still same message when being hooked up to Lenovo. What do I miss here? How do I change to VGA to get input signal? Or simply just does not work with this monitor because of the resolution incompatibility? Thanks, Young
  • HP Master
  • 2,007 Answers
Wow no OS stated, nor model of Lenovo.... (so generic answers)
i guess you have no manuals on any of this. right>?
is this HP question, if the HP monitor works on other PC its ok.
so end HP worry. (my guess is HP is OK, totally) 19"LCD is OK.
leaving what, LENOVO.!! (unnamed? a stinkpad?)
this is a HP forum, so cant tell the hot key for External VGA
on any Lenovo. but you can RTM the book on it. easy.
that HP VGA monitor message means.
1 thing, the 3 video and 2 sync lines are dead.
in non geek means the VIDEO CABLE IS DEAD.
try running the PC in F8 mode this puts WINDOWS< (is it./)
in to LOW RES mode (poor) and all monitors work there.
all. (last 25 years)
if still dead, you need to use the hot key to turn on VGA, on all laptops
my HP laptop as 3 modes, VGA on , VGA off and AUTO.
nice no? that AUTO.'
The PnP wakes up the port. is that magic.
The VGA port must work, and the LCD both.
is this one of those beasts called an all-inone desk top
than name you used tells the helper nothing
as that name used for many form factors.
all in one
regular desk tops.
and more.even pocket pc.
now idea at all what you have (hp is clear on that end=)
Posted on Apr 15, 2017
5 Suggested Answers
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
  • 31 Answers
SOURCE: VGA no input signal, monitor is going to sleep
try this
Posted on Sep 15, 2009
  • 31 Answers
SOURCE: Hp w1907 Monitor going to sleep
try the link provided
  • 105 Answers
SOURCE: hp w1907 has white screen in vga and dvi-changed
The all white screen indicates loss of 5 VDC to the LCD panel. Either the connector is not plugged in good or (more likely) the panel itself had failed. They can develop a short that blows the 5 V fuse on the panel. Replacing the fuse normally does not fix the problem.
Monitor Mike
Posted on Apr 30, 2010
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
Hp w1907 monitor cord does not fit my hp computer is there any adaptors i can buy
Yes there are many adaptors, go to your local computer store and find the correct one.
Take note as there a number of connection types as shown below:
VGA blue connector.
DVI White connector
HDMI ususally a narrow black connector.
Mar 21, 2011 | HP w1907 LCD Monitor
HP W2007monitor VGA No Input Signal DVI No Input Signal Going to sleep
try HDMI? also switch ports on video card in case there are 2
Mar 01, 2011 | HP w1907 LCD Monitor
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
70 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
