KARAOKE SINGING MACHINE-Model STVG-999 suffered trauma. needs re-wiring. repairman needs schematic diagram to perform the surgery. whare can i find schematic diagram to save the life of my old friend?
4 Suggested Answers
Xtremeroofin
  • 67 Answers
SOURCE: I want to get the
Ok from the looks of it... the three RCA plugs on the bottom left are the video out audio (right&left) out use the video out and plug that into your video in on your tv then for sound do the same for the right&left audio
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: The MTV Singing Machine STVG-700 Manual
I found the telephone number of the company, called and they e-mailed me the owners manual immediatley!! At no charge!
Thanks for trying to help me. I'm sure I will be back as I still have a few more manuals that I need!!
Michele
Posted on Aug 15, 2009
reyjoshua07
  • 1157 Answers
SOURCE: c.d. on karaoke will not
Hi elakerfan200,
If your singing machine CD player turns on but does not spin, it is often caused by the lens. The easiest way to correct this problem is as simple as the lens may need cleaning. Here are several troubleshooting steps that you can take:
1. Remove excess dust from the CD player. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
2. Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
3. Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
4. Make sure the slider that the lens is attached to is all the way back to the platter.
5. Check the platter, it may have slipped down to close to the lens and it wont focus.
6. If the above steps did not work, the motor drive circuit is defective. At this point you need a help of a repairman to check the unit.
Hope it helps.
Thank you for using FixYa.
Posted on May 07, 2011
I need a manual for STVG-988 Singing Karaoke machine 2004
Just about everything is available on line, if not, then call the manufacturer.
Dec 16, 2017 | Audio Players & Recorders
Screen quit working
Sounds like it has taken a pretty hard jar Remember to rate my help and if you need further help just shout thanks in advance. I would open it up and make sure all connections are together and have a space filled that one plug has come undone in the system somewhere this is most likely your problem..
Nov 09, 2013 | Singing Machine STVG-999 Pedestal Karaoke...
Instruction booklets on machine
Many of the Singing Machine Karaoke system manuals are available on the company's support site: http://www.singingmachine.com/support/instruction_manual.php . The direct link to the STVG-1009 manual is http://www.singingmachine.com/download/Instruction_Manual/2010/CDG/STVG-1009/STVG-1009%20IM%20E01%20(SMC%20US).pdf .
I hope this helps.
Mar 24, 2012 | The Singing Machine Singing Machine...
I have a STVG-500 and the CD Player is not working.
Here's a shot in the dark ...try loosening the screws that hold the printed circuit board. It worked for me.
Feb 06, 2012 | The Singing Machine DVD/CDG Karaoke System...
Mic doesn't work
Hi Troy,
Have you inserted the mic in the right input? Make sure it is not inserted in the headphones input. Besides that take a look at the display menu and make sure the volume is turned on.
Mar 09, 2010 | The Singing Machine SINGING MACHINE...
The Singing Machine - STVG-1008
sounds like the rom drive needs to be cleaned had a similar problem with a kareokee machine when i was 16 used electrical contact cleaner and some cotton swabs with a cleaning disc and it worked fine
Feb 18, 2009 | The Singing Machine DVD/CDG Karaoke System...
The singing machine stvg-513 cd player wont work
These are a pain in the **** to service. I have a -700 in the shop right now I'm working on, the drive tray was jammed, so I freed it up (trial and error), and while I didn't notice the first time I checked, the flat-film ribbon cable that plugs into the optical (read) head had gotten some of the conductive traces scraped off. I took a cable from a working unit, installed it, tweaked the laser drive just a bit, and now the drive reads track 0 (with the track info). What I haven't yet figured out yet is why none of the CD controls work (>, <, <<, >>, ||, etc.). This isn't terribly advanced service, but it's beyond beginner level.
Dec 21, 2008 | The Singing Machine SINGING MACHINE...
Display keeps saying door
When your site kicked me out and charged me twice, I through the singing machine away! that solved the problem.
Jul 04, 2008 | The Singing Machine SINGING MACHINE...
95 people viewed this question
 Grubhead
Grubhead
