Question about Acer Computers & Internet
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
  • Acer Master
  • 27,725 Answers
The beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 08, 2010
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Nov 22, 2013 | Fujitsu AMILO Pro V2055 PC Notebook
Phoenix bios
Are you sure this isn't a 4 beat sequence? such as 2-1-2-1?
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Game Stuck in console
Try Go to settings and eject it from the inside
Nov 16, 2013 | Sony Playstation 3 (PS3) Console
My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
hope this helps
Dec 29, 2010 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
It has a strange sound on boot: 1beep 3 beep 3 beep 1 beep and it doesn't show anything on screen, the harddisk is working....butI can't see anything
Check if your RAMs are properly seated on their slots and make sure if the connectors are free from dust, rust or corrosion.
Oct 13, 2010 | IBM ThinkPad A30 2652 Notebook
PSP screen problem
It is most likely a screen problem, perhaps the screen is disconnected. I would suggest having it serviced, or perhaps you can try to disassemble it and check the cable is fully plugged in.
Jan 29, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
