Question about Samsung TSL3293HF 32" TV
    Problem Solver:
  • 10 Answers
Posted on May 30, 2008
Rca com television
I would say your set needs a service engineer who is familiar with this model/make, sets shut down for various reasons, under No signal conditions they will or if a fault causes this state. They react to faults caused by faulty components or solder joints that have become poor so switch off to protect themselves and more so you, heat can make parts fail. If it recovers each time then the odds are good it can be fixed easily but by waiting the fault may cause further component damage so then beyond repair. If it otherwise works OK and you can get it fixed then please do before the fault makes things worse.
Aug 28, 2014 | RCA 14F514T 14" TV
Clicking sounds
You must obtain the service manual and identify the parts from the layout diagrams.  It is not an easy job and is even one that advanced tv techs have trouble with.
You may want to spend the money to have a qualified expert do the job because the set should be analyzed first to make sure you know what is causing the problem.  I can only be about 70% sure by long distance diagnostics!
Feb 26, 2008 | Samsung PCL5415R TV
Tv isnt turning on, you will hear a click then see the power light flash 6 times then the light goes off for about 10 mins then comes back on flasing again...and the cycle just continues. It did this once...
Sounds like a power supply problem. I worked for a short period for Panasonic at their USA plasma R&D / small scale manufacturing facility and learned that to "ignite" or start the plasma when turning on the set, a significant current discharge is required.
The recycling seems to indicate that the "brain" in the set realized that a plasma has not been established, and it is attempting to recharge the starting circuit. The flashing power light is probably significant and a trained technician or a service manual will probably identify this as a trouble code pointing to the problem. Sorry, I did not have any exposure to the finished product and cannot advise what the code means.
If the set is still under warranty, you should act immediately and get the problem taken care of, because it will not go away on its own, and will most likely get worse. Sorry the news is not better. Good luck!
Jan 28, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
Oct 16, 2010 | Sony KP-53HS30 53" Rear Projection...
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Watch TV and it shuts off after 10 min.s
Its the power source of the TV, something is causing a change in the power supply or the TV is sure but one of the two...I had the same problem...I think they changing the power source and its back to normal.
Sep 10, 2009 | Televison & Video
Settings window keeps popping up on tv screen
Since the menu will come up randomly it may be a hard issue to resolve. If it is the remote that is causing the menu to come up you can do some trouble shooting yourself. You could take the batteries out of the remote and see if the menu comes up when the batteries are out. If it does come up then the issue is in the television set and may require further trouble shooting. Please let me know if I can assist you further, respond to this post and I will try to help.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv takes 30 min to cut on... but when it does no picture shows.
LOL sounds like you just need a new TV buddy, there are multiple components that are going out, first start with the green lines or "pixelations" these are caused by the tv no longer being able to regulate the electricity in those pixles and are as a result 'Open'. The 10 minute things is more of a energy conversion thing and sound and video on and off are connection issues (internally) so take it to a repair shop but if the price to fix is greater than 1,000 you should be willing to scrap it for a replacement. who knows the shop might buy it off you for cheap...
Good Luck
This is my Fav...
pricey though but can keep an eye on ebay for half price divorces.. :D
oh and my site
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Plan on fixing or replacing the power board soon. It will keep getting worse until, the end. There is a small bright side. It is the best damage to sell your broken tv "as-is" online. Someone will come pick it for sure.
Sep 12, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Samsung TSL3293HF 32" TV Logo
197 people viewed this question
Jerry Greenberg
Jerry Greenberg
