Question about Sony VAIO PCV-RS530G PC Desktop
Cannot Boot up Computer: sends me to the bio screens
How can I change bios to get computer to boot up and recognize the hard drive, the S M A R T even does not recogizne
  • Anonymous Mar 04, 2009
    I bought a new seagate 80 gig sata hard drive trying to replace my old pata harddisk. the motherboard has a sata slot (2) and the model of the motherboard is ecs p4m800. but when I boot the pc it doesnt detect my harddisk...Please help...
    Problem Solver:
  • 19 Answers
I presume you know how to get into the BIOS, but you don't say if this is a new drive being replaced or a second drive being added etc., but I'm guessing that you don't have the drive configured correctly. There are three jumper positions on most drive to set the drive as a Master (M), Slave (S) or Cable Select (CS). Some systems are set to just use the Cable Select setting and the drives are configured based on their position on the ribbon cable, others must have one drive configured as the Master and the other as the Slave. Often a single HD is installed with the jumpers removed or turned sideways to disable the settings which is OK for a single drive, so if you adding a second drive, remove the first drive and if it is on CS, set the new drive to CS as well, but if the original first has the jumper set sideways or has no jumper at all, then you need to either set it to CS if your system supports it or set your boot drive as the Master and the new drive as Slave. CD Roms count as drives and if on the same ribbon must be configured the same way.
Most drive manufacturers have web sites that will help you configure the drives correctly, so check their sites for instructions on setting the jumpers.
Good Luck
Posted on May 29, 2008
I am having the same issue but not due to a HD change. It just started doing it on a dell laptop. I have checked to see if the key is stuck. I have removed the key to look for debris and so on.
I did however find a way around it by holding F8 upon boot, which gives you a boot option screen and then you click start windows normally. I also had to disable the fn button scheme in the bios so the internet adapter wouldn't become disabled then enabled off and on contantly. I am at a loss as to how to correct the issue.
I would consider a bios flash as some had recomended that I try that in order to correct the issue, but if I do from windows as opposed to flash drive as dell would have me do I wonder if I run the risk of a bad flashing compromising the system.
Is there a way to do key reassignment to enter the bios until I can figure out the problem with the keys?
Posted on Aug 26, 2012
    Scholar:
  • 60 Answers
This might sound stupid, but check your function ("f_") keys at the top of your keyboard to make sure none are stuck. Especially the F2 key which is the most popular key to enter BIOS setup and the 'esc' key.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
P4 bios setup boot
You haven't supplied much information on the boot problem ?
Restart your computer and enter BIOS mode.
On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on.
Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it.
Once you've selected your desired options, continue to boot.
Jul 01, 2013 | IBM Computers & Internet
Messed up an IDE partition now BIOS won't recognize drive, can this be fixed or is there a workaround?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? Hope this helps.
Dec 09, 2012 | Computers & Internet
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
My laptop crashed and we installed a new hard drive, as HP said, but we received a message that it did not recognize operating system. So we ordered recovery disks and put those in turned it on, still no...
ok, First you should understand the new hard drive is empty, it is not even formatted. At this point the most likely issue is the bios not recognizing the Hard Drive because the Bios is not set to automatically detect the hard drive. Enter the Bios and go to the hard Drive selection sub menu and have the computer automatically detect the hard drive size and type. Then go to the boot sequence menu and alter the boot order to CDROM, Floppy (If you have one), Hard Drive, Network. Reboot the computer and you should see the RAM test, hard Drive Identification and then the CDROM should start to boot. I can't be more specific about the steps because your post didn't include the model of the laptop. All of this assumes your CDROM is still in working order since HP laptops have a known issue with CDROM's going out for no reason. The hard way for dealing with this would be to get an encloser to put a hard drive in to make it portable and connect to another computer and do the partitioning and formatting of that new drive on the other computer and solve the problem that way.
Feb 16, 2011 | HP Computers & Internet
I replaced my HD on Dell inspiron 9300 and it won't recognize the new drive. The new drive was also purchased from Dell and was one that was compatible with the computer. It's saying there's no bootable HD...
It probably has found your new HD, you need watch the screen as you attempt to boot. Failing that enter the bios (usually " hit DEL to enter setup" appears on the screen. Don't change anything but just check to see if the bios has detected a hard drive.
Now .......... the reason why it won't boot is because you have to re-install windows onto the hard drive.
May 04, 2010 | Dell Inspiron 9300 PC Notebook
Realtek media test failed check cable pxe exiting flashing
As the computer starts hit F2 to get you into the bios, look for boot options and set the HDD (hard disk drive) to the first boot device, hit F10, save the changes and exit the bios. The computer will restart and should boot from the hard drive. If it doesn't go back into the bios and look to see if the drive is recognized in the main page of the bios.
If the hard drive is not there then there could be a chance that the hard drive has failed.
Please let me know how you get on and if you need any further assistance.
Good luck.
Aug 26, 2009 | Acer Aspire 5100-5022 Notebook
Dell DV051 - message no boot device
Go into your BIOS by pressing F2 and see if the hard drive is being recognized in there. If it is then reset defaults in the BIOS and reboot and see if the computer will boot back into windows. If it doesn't then you'll need the discs to restore the computer back to factory defaults. If the hard drive is not being recognized in the BIOS then make sure the hard drive is hooked up properly. IF it is and its still not being recognized in the BIOS then the hard drive is bad.
At that point then you'll need to replace the hard drive and use your discs to restore the computer back to factory defaults.
Aug 07, 2009 | Dell Inspiron 530 Desktop Computer...
Sony VAIO PCV-RS530G PC Desktop Logo
164 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
