Question about Ricoh Aficio AP3800C Laser Printer
Problem with Paper
When printing the paper comes out hot and ripled
  • Ricoh Master
  • 691 Answers
The paper will always come out hot as the toner is fused to the page using heat and pressure - like an iron!
The ripples could suggest that there is an obstruction in the fuser unit. Whip it out and check to see if a piece of paper is stuck in it. Let it cool down first for 30 mins or you could burn yourself.
Posted on May 29, 2008
Paper printing hot and curling on kyocera taskalfa 300i.....how do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
Dc 12
Did you check the sensors?
Feb 28, 2008 | Xerox DocuColor 12 Printer
Paper is coming out extremely hot
check the paper type settings.
Sounds like you are yanking up the fuser for heavy paper/stock card instead of setting it for standard 90g
Nov 08, 2013 | Konica Minolta PagePro 5650EN - Printer -...
Trying to print on laser photo transfer paper, but printer seems to be too hot for it - is there any way to print on this transfer paper?
i tried to print on laser paper too but fuser is too hot. its melting the paper and getting jammed right? i got tired of printing on laser paper and converted to inkjet paper. this is much easier
Jul 14, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
When printing on my HP 4200 printer, the pages are coming out hot
Simple answer:  It's Ok if the paper is coming out hot out of the printer. The paper passes the fusing assembly just before it leaves the printer and that is normal.  I would be worried it you smelled something burning or saw scorch marks on the page but that would be unlikely since there are temperature controls built into the printer.. There is a way to adjust the temperature of the fusing assembly from the printers control panel depending on the type or thickness of the paper but it'd leave it alone if your only problem is feeling that the paper come out hot.Your user manual would describe the procedure if you wanted to change it..  Also check your printer configuration settings. If you sent a print job on regular 20lb paper and its stated as thick paper type  in the printer settings, the printer might adjust the fuser hotter or slow the printer down some to compensate. Hope this helps
Dec 18, 2008 | HP LaserJet 4200n Printer
Colour printing
If its a Canon printer try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
13. Start printing.
Jul 01, 2008 | Canon Office Equipment & Supplies
Pixma IP4000 Printer
OK, Canon will hate me for posting this!!!!!
Remove cartridges.
Remove print head.
Go to sink or tub (stianless steel, not pastic type), pick up roll of paper towel on the way.
Run HOT water till HOT.
Turn hot water to dribble.
Run hot water through print head, careful not to wet contacts.
When water is clear coming through print head, place print head on paper towel.
Repeat process until no colour on paper towel.
DAB print head (DO NOT WIPE) inside and out to dry.
You may wish to let print head air dry overnight but I replace it after drying.
Replace print head in printer and replace cartridges.
Start printing again
I do this on all my Canon printrs every 6 months
Jun 30, 2008 | Office Equipment & Supplies
On my canon i950 printer, a green line prints out at the whole bottom edge of the picture when it is printed. I have done the deep cleaning and it still comes out like this.
Try this then.
13. Start printing.
Jun 30, 2008 | Canon Office Equipment & Supplies
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
