Sir I Have DLINK DES 3526 L2 mangable switch, its earlier configured an ip which is 192.168.1.17 using this ip i access the switch yesterday and i change it to the DHCP configure but now i want to allot a static ip to the switch again how can i do it? if there is any reset button please help me
    President:
  • 2,185 Answers
All Dlink routers has a reset button at the back. Just use a paper clip to press and hold that button hole until the router turns off itself and restarts again. Your router will then return back to defaults with 192.168.0.1 IP address.
Please let me know if this helps. Thank you for using FixYa.
Posted on Oct 08, 2010
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have forget the user name and password for the swtch i.e D link des 3526.kindly send me the procedure of how to reset the configuration
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link;s configuration URL.
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now go to the wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | D-Link (des-3526) Networking Switch
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Configuration
The DES-3526 has a lot of features and it would be quite hard to teach you everything through FixYa.
I suggest you start by carefully reading the manual. Everything is very well documented:
ftp://ftp.dlink.com/Switch/des3526/Manual/des3526_Manual_500b27.zip
Then, once you have learned more about it, if you still have problems, feel free to write back and we will help you.
Apr 14, 2008 | D-Link DES-3526DC (DES3526DC) 24x10/100...
DLINK SWITCH DES-1008D
other units cant connect to my installed port hub and were having hight mare connecting it
Apr 09, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
Configurtion
Hi prasad, Here you go: ftp://ftp.dlink.com/Switch/des3226/Manual/DES-3226_MIB_manual_170.zip All support info and downloads for that switch can be found here: http://support.dlink.com/products/view.asp?productid=DES%2D3226# Hope that was fast enough for you!!! Good Luck, El Duderino
Nov 17, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
