Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Heater and fan are not turning on at all. - Raypak Free Hydraulic Lift Gate Delivery - No L...
    Top Expert:
  • Raypak Master
  • 4,292 Answers
If power to unit check safety circuit
Posted on May 25, 2016
Why blower fan won't turn off after i turn off ac/heater
You relay switch is stuck on. Replace it. Second thing to check is the fan switch may need to be replaced. If you turn off your engine and then back on does the heater fan go on even when it is turned off at the switch?
Jun 22, 2014 | 2006 Ford Explorer
2003 Alero, heater won't shut off? Fan shuts off but can't turn heater off.
Faulty heater control valve.Its located under the hood on the passenger side in front of the firewall.
Oct 29, 2012 | 2003 Oldsmobile Alero
My 02 nissan pathfinder interior fan runs even when not turned on.checked all fuses they seem to be fine.
If fan still runs when all your heater control knobs and buttons are off, it is likely a bad heater fan switch. Unless you have something like a body control module found on newer cars that has some control over interior functions. If not, try a new heater fan switch. Good luck.
Jan 18, 2012 | Cars & Trucks
How come heater fan wont blow
there are a few things that will cause this problem.
1. it could be the heater fan fuse
2. could be the heater fan motor itself
3, a bad switch or relay
check the fuse and then check for voltage at the heater motor itself, if you have voltage at the heater motor,, give the heater motor box a love tap with your hand and see if it starts to turn, if it does not turn or even if it does ( after tapping it ) - it is time to replace the heater motor.
c...
Jan 04, 2011 | 2000 Jeep Grand Cherokee
When I turn the heater on, the motor sounds like it wants to turn but there isn't any heat coming out
the fan will run whether or not the heater core is getting warm, it does not care. you can hear the fan run, sounds like a fan running. if there is air coming out the vents and you hear the fan running, then the problem lies with the heater core.
Dec 16, 2010 | 2004 Mitsubishi Galant
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
Jun 18, 2017 | Saturn SL2 Cars & Trucks
93 Subaru Heater fan not working
Have you checked the earth? You may find current is going to earth via the fans. Find the earth for the heater and make sure it is earthing really well. Hope this helps.
Feb 28, 2009 | 1993 Subaru Impreza
Heater turns on and clicks right off no fan
Take unit apart and thoroughly clean ( vaccum out) the fan area. if it is dirty you should blow out accumulated dust from the same area, if the fan does not turn freely the unit will overheat and shut down
Feb 14, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
32 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
