Question about Brother Sewing Machines
Was sewing a quilt together...machine was doing fine. Then it just stopped.. tried a different fabric and it sews fine
    Genius:
  • 1,788 Answers
Try a different needle, you may have to the wrong size and your machine is working to hard to overcome it, maybe overheating.
Posted on Oct 10, 2010
My machine is adding loops under my stitches when I try to stitch a straight stitch, I am trying to machine stitch a quilt top!
Quilting is a bit more finicky than regular sewing. Be sure to ALWAYS RAISE the presser foot when threading the top thread. FWIW, I use a separate bobbin case for FMQ that I have tightened the tension to keep the bobbin thread from coming to the top of the sandwich, but I tend to use a finer thread for quilting so adjusting the bobbin takes care of it. In your case, however, it sounds like the top thread is staying under the fabric. I would try tightening the top tension. Also, install a brand new needle--a top stitch, embroidery, or microtex needle seem to work well for me. Test well on a sandwich made of the same fabric and batting and get it adjusted well before sewing on your quilt. Sometimes sewing speed will affect stitches under the fabric, or even on top.
5 Free Motion Quilting Problems and How to Fix Them
Correcting Sewing Machine Tension for Free Motion Quilting NQC
LOOPS Tension or Speed
https://www.generations-quilt-patterns.com/machine-quilting-thread.html
https://www.generations-quilt-patterns.com/sewing-machine-tension.html
https://www.generations-quilt-patterns.com/machine-quilting-tension-problems.html
Feb 27, 2018 | Sewing Machines
I have a Kenmore 385 17724490. When I use the zigzag for my quilt it works great for a short time then it goes straight. What do I need to do for it to keep the sew zigzag ?
try this take machine oil and oil eerier where the buttons that
changes for different stiches, then set the machine for straight
stich take a piece of fabric and sew on it for a 1 minute do the same for every different stich do this for halve hour, by doing this
your getting the different stiches in order and gear to synchronize
together.
hope this helps.
Feb 08, 2018 | Kenmore Sewing Machines
What foot and setting do I need to sew strips of bias binding together.
If you are sewing bias strips end to end, any foot would work. A 1/4" seam allowance is probably fine. You'll probably just need to cut the ends @ 45 degree angles and match them up before stitching. Sewing them at 90 degree angles creates a big bulk of fabric whereas 45 degree angles spread the bulk out when applied to your cushion fabric.
Learn How to Join the Ends When Quilt Binding Tips from McCall Quilting
Mar 16, 2017 | Sewing Machines
How do I set 8900 for free motion quilting? D4S mode and QB-S foot
To do free motion quilting on most machines, install a darning foot or free motion quilting foot, drop the feed dogs, set the machine to straight stitch. (Because FMQ requires you to manually maneuver the fabric, stitch length is moot.) If your machine has the feature, setting it to Needle Down will also help. When you stop sewing, the needle will stop while penetrating the fabric. This prevents you from accidentally moving the fabric while trying to adjust before sewing again.
Free Motion Quilting Beginner Tutorial 1 of 4
Jan 11, 2017 | Sewing Machines
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
I am using my walking foot to stitch in the ditch my quilt. The foot is not pulling my fabric through consistently.
The quilted fabric may be too thick for the walking foot to move along smoothly. Try using a zipper foot which is much slimmer and can get close to the line of stitching.
Apr 18, 2015 | Brother CS6000i Computerized Sewing...
Bernina walking foot
Hm, just guessing here.
Have you checked to make sure the walking foot (u-shaped) bar is still attached to the needle bar? Are the feed dogs still in the up position and operating like they should?
Learn How to Use Sewing Machine Walking Foot
Something else that I've run across in my sewing adventures is that walking feet need periodic oiling to keep them operating. Just manipulate the walking foot with your hands and watch where there are moving joints. Then apply a small drop of good quality sewing machine oil to each joint. Work it in and then wipe off the excess so it won't stain your fabric.
May 21, 2017 | Sewing Machines
Can I use my singer simple 3116 to quilt
you could probably do light quilting on it, you'd probably
need to buy a extension table for it.
here's a link for parts for the the machine, they do have a extension
table you might be interested in.
http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx
Sep 22, 2012 | Singer 3116 Simple
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
