Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor hpvs17e stays on for second and goes blank
  • 732 Answers
Gldngrlz411, most likely problem with internal "switch-mode-power-supply" / CCFL inverter supply that provides 600 to 1000 volts ac to light the CCFL tubes that provide "white light" so you can see what is on the glass LCD panel!! Explore here first: http://www/lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ If vs17e does same when connected to a different "known good" pc, then you will need to make big decision!!! FIX or Trade in for new wide screen unit. 12fixlouie
Posted on Oct 08, 2010
    Director Badge:
    Uploaded 100 video answers.
  • 225 Answers
I had this same problem and fixed it. My problem was on the inverter board. The inverter board side has the pink/whit & blue/white wires plugged into it. What is happening here is the inverter is going into over voltage or open lamp mode. First thing is to check all the electrolitic capacitors for bulging or leaking (most likely not the problem here). Next thing is to touch up all the solder joints on the inverter board (there's not many). Make sure when you plug it all back in that you have the blue/white wires on the inside and the pink/white wires on the outside. If that doesn't fix it then replace the surface mount 8pin inverter chip U1 part # OZ9936GN (that's what fixed my problem). Got the part from http://www.utsource.net/
Posted on Nov 10, 2010
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
May 17, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
895 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
