Question about Brother MFC 210C All-In-One InkJet Printer
My printer reads, "Cannot detect Black Ink. Reinstall slowly." I have done this several times and I still get the same message. It had also said the same for the yellow ink but I reinstalled the yellow ink and now it is okay. Thank you! Pat Wrobel Dickens
  • pwdickens Oct 08, 2010
    Thank you for your quick reply.
    When I did what you said, it read "No cartridge (even thought the black ink cartridge was in). Open ink cartridge cover, then reinstall ink cartridge."
    I don't have a cartridge cover so I did what you said to do again and then I got the first message, "Cannot detect Black Ink. Reinstall slowly."
    Help!!!
  • Brother Master
  • 19,396 Answers
Hi PW.
Clean the contacts inside the ink carriage. I mean the metal plate inside the slot where you put the black cartridge, clean using isopropyl alcohol or circuit cleaner solution.
Try again. Brother printers may give some trouble with ink detection, if problem persists you may need to turn off both printer and computer. Then disconnect power cord from printer and PC (power drain may help). Restart the whole system and try again.
If still no luck, then the chip in the cartridge may be defective (quite common if cartridge is not original or refurbished).
If the above did not fix the problem, and the cartridge is NEVER detected, even after trying different cartridge, then the wiring to printhead located at the back of ink carriage is broken. Testing is done reading Ohms between the plate contacts inside the ink carriage and the wires at the back of ink carriage.
Regards.
Ginko.
Posted on Oct 08, 2010
    President:
  • 4,070 Answers
Hi! Please try this. Uninstall the black ink again then remove the printer from power source. Press hold the power button for 10secs. while unplugged to reset the system. Plug the printer again and reinstall the black cartridge. Please shake the cartridge a little bit before installation. HOpe this helps and thank you for using FIxYa!
Cannot detect black ink reinstall slowly
your developer is weak or check tonar detective sensor
Mar 24, 2014 | Toshiba e-Studio 232 Black and White...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
It alwayas says on a printer screen "reinstall slowly cannot detect black ink" please help!
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 25, 2011 | Brother DCP 165C Compact Color Inkjet...
Black ink cannot detect reinstall slowly
HI Good day!! Remove all your ink cartdrige and insert it 1 at the time slowly.. I think your using brother printer.
if not work please reply i will assist you more..
REGARDS
JR
Oct 18, 2010 | Office Equipment & Supplies
Black not printing
My refill my printer ink (i remove it) but still the screen appear to ask me "cannot detect black ink, reinstall slowly"
Apr 05, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a new LC61 and just replaced the blk
Leave the machine on with ink installed, unplug power for a few seconds and then plug in while you hold the stop button for a few seconds. Should clear the error for you, if not you may need a new ink sensor board.
Jan 08, 2010 | Brother Multi-Function Center MFC-240C...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 215C :yellow and red refuse to print
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Brother MFC 210C All-In-One InkJet Printer Logo
321 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
