Question about LG LS-K1830CL Cool Mini Split Air Conditioner
I installed a 2400 BTU Senville mini split ac unit about 6 months ago and until now, it worked great. Tonight I noticed my room getting hot and looked up at the wall unit and it was flashing "f5" I think? I turned it off and on and it seemed to return to normal with 65 degrees displayed yet when the room stayed hot, I went out and looked and the compressor was not working. I flipped the breaker and still nothing, went inside and turned it on and off again, still no compressor, no cooling. Thanks in advance for any advice.
  • 400 Answers
SOURCE: LG ac M483CS not cooling
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Posted on Mar 04, 2009
  • 148 Answers
SOURCE: I am trying to decide which 12000 btu Mini-split
HAVE HAD VERY GOOD EXPERIENCES WITH BOTH UNITS BUT I THINK DEPENDING ON MODEL THE LG IS BETTER
Posted on Jun 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
Posted on Jul 08, 2009
sams_trix
  • 93 Answers
SOURCE: room at 84. unit set at 65. outside is 94 degrees.
I brows the web to see the specs of your unit.In that case the unit cannot cool down the room temperature, you must consider the following:The volune of the room, it might be exceeded the specified capacity, the thermal isolation of the room, must be shield from leaks,and the materials used,the absorption of the matterial at first operation, the materials around the area will absorb coolness prior to room air, and the ambient temperature outside may affect the performance of the system,If too hot outside put a better thermal isolation inside.that helps? need thumbs up... sams_Ew0rks**
Posted on Sep 02, 2009
SOURCE: senville mini split codes
Put gage on low side and check the pressure running. if it is less than 125 you probably have a leak.
Posted on Dec 18, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
Senville mini split heat pump is stuck in defrost mode
Did you find a solution to this? as I now have the same problem???
Dec 31, 2014 | Senville 18000Btu 21 Seer 12.5 EER...
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Oct 17, 2009 | Frigidaire FAA055N7A 5200 BTU Room Air...
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
246 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
