Question about Cameras
No power
Haven't used it in a while and stored it with no batts. in it and now it wont power on. the last time i used it it worked fine?!?! Help JB The battery for this Camera I am not able to find at all. I can find the camera but not the battery. The battery I have is not wanting to charge but when i have the camera connected to the wall charger it works. So confused. Can anybody help me please. :(
  • Samantha7755 May 29, 2008
    AKAI 8.1MP DIGITAL CAMERA DS8341
  • Anonymous Feb 12, 2009
    Ye, I and a friend have the same problem. Replacemnet batteries do not seem to exist.
    D
  • 10,594 Answers
Battery has gone. camera works fine on charger means camera is OK. by the way, whats model n make of your camera?
Posted on May 29, 2008
  • Shahid Electronics
    Shahid Electronics May 30, 2008
    Sorry, Sony products are my field. I am unable to assist you for Akai.
No power and batt is good
My first guess would be a dead cell inside the battery, or a blown fuseable link between the battery and the fuse box.
Someone would need to check the battery connections and fuse box with a meter.
Jun 01, 2013 | 1996 Ford Taurus
I replaced my starter on my 85 lic.town car and also the silanod last week and now the silnoild works but the starter wont work. the starter wants to stay on all the time? when i took the starter off and...
If starter is staying on "all the time" - your solenoid is bad. Solenoid controls power to starter. Try another solenoid and if problem continues you have a bad ignition switch.
Mar 05, 2011 | 1985 Lincoln Town Car
I have the same problem, the batteries do not last. Just bought new high quality batteries and put them in. The camara is already showing low battery and turn's itself off (just after putting them in,...
this occurs in any device that uses battery/s in some cases a small short forms that drains the batts there is only two fixs have the fault found by a service tech and repaired ( expensive and very hard to find) or store the batts out of the camera untill its being used now if the batts are not lasting in the camera then its the batterys simple. always remember with units such as camers always always use rechargable batts they give a heck of a lot more power drive than shelff pre charged batts
merry christmas
sonic boom electronics australia
please take the time to rank this advice below
thanks
Dec 24, 2010 | Fuji FinePix S3000 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Will someone help me?
If you have read the user manual on page 16, this camera only compatible with two kinds of batts: alkaline or rechargeable batts.
Mar 30, 2008 | Fuji FinePix A900 Digital Camera
My kodak easyshare cx7330 camera wont turn on how do i fix it
USE ONLY LITHIUM BATTERIES.
Alkaline batteries don't last long and often can't supply sufficient power on start-up... even when they are new!
Lithium batts cost more, but they last way longer than the equivalent $ value of alkaline batts.
Dec 02, 2007 | Kodak EasyShare CX7330 Digital Camera
No power
Call 800-726-4405 - request a replacement
Nov 29, 2007 | Akai DC6371 Digital Camera
No power
Mkae sure you are you using lithium batteries
Gps wont work it is frozen
Well Sprinkler, I have one also and had a similar problem. But I took SD card out and Batt. for 1 hole day and put back in first the batt and tried power up and it come on. I think my SD card caused the problem. Hope this helps!
Sep 20, 2007 | Audio Players & Recorders
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
