Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Brushes not spinning....
Hi, i have the roomba 4210 discovery. Both brushes stopped working. Everything works fine except for the brushes. I called roomba technical support and they said i need a new one, because i damaged something that makes the brushes spin. They weren't very helpful at all. Please help.
  • 3 more comments
  • tmawp Jun 18, 2008
    thank you for your help, i try cleaning all the brushes and i got the same result. I sent in my roomba 4210 to roomba exchange to have a diagnostic testing. They said, i stripped all the gears to the motor that makes the brush spin. So, for $40 they included the diagnostic testing, brush motor assembly and they send it back to you. they also have very good customer service.
    they say this happens, when your roomba get stuck for too long and is unable to get itself free. For instance carpet with tasso or wires.
  • Anonymous Mar 17, 2014
    roomba 680 spinner brush not spinning
  • Anonymous Mar 18, 2014
    roomba brushes don't spin
    roomba 650 brushes stopped spinning
    Problem Solver:
  • 5 Answers
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
Posted on Jun 18, 2008
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba discovery
Cleaned the shaft that the spinning brushes are connected to. Used an eyeglass screwdriver to remove the brush.
Jun 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Stops
I just fixed mine by cleaning the shaft that the spinning brushes is on. I used an eyeglass screw driver to tke out the screw. it is running great now. I didn't realize my brushes werent spinning at the time of my post. Cleaning this part seemed to have fixed the problem.
Jun 03, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Brush keeps running
The problem is in the Roomba itself. It can't be fixed-- time to call support.
Feb 17, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
2,027 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
