Question about Fisher and Paykel Washing Machines
Hi We have a Gentle Annie GW 52 As the spin cycle picks up speed the machine shuts off. There is no load in the machine, the pump is clean and when I remove the drive belt the engine seems to come up to speed OK. Any ideas??? Thanks Terry
    President:
  • 1,932 Answers
This because the belt have become loose.As when spinning the speed goes up and the belt starts to slip off,so it seems to be the washing machine shuts off.Change the belt with correct size and this problem will be ok.
Thank you
Posted on Oct 08, 2010
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Spin cycle keeps restarting
Likely to be motor, specifically the brushes. depends on how old the machine is. brushes are replaceable and tend to need replacing from4-5 years with some makes
Dec 08, 2013 | General Electric WCVH6800J Front Load...
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
GW 612 Fiaher Paykel wont complete drain or spin cycle
Do you get any errors on the display lights?
Dec 03, 2012 | Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Hi Experts, I have a 1988? Fisher & Paykel GW51F top loading washing machine, and last week during the spin cycle, instead of draining & spinning, it just hummed for a few secs (draining, I...
Hi just read your posting.Is this machine a Gentle Annie model?Does the machine drain at all?The web address to watch the video of your machine does not work.Please reply with correct address and the name of your machine and I am sure I can help you.Looking forward to your reply.
Sep 20, 2010 | Washing Machines
Gentle Annie wont pump out water
could have a sock in pump vac and towel needed unplug empty water remove drain hose shop vac pump and both hoses turn on to see if pump motor runs
Feb 04, 2010 | Frigidaire Washing Machines
Hi.I have a Gentle Annie that starts and stops filling with water
It is most likely the lid switch. The switch sits in a plastic bracket which has a lever coming down behind the tank.
If the tank sways and hits that lever, it cuts off the cycle as a safety measure. When the switch is faulty or more often when the plastic bracket breaks, you get this symptom.
Let me know if you need more assistance.
Ash
Oct 22, 2009 | Fisher Washing Machines
Washing Machines Logo
66 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
