Question about Craftsman Air Tools & Compressors
I have a central pheumatic stapler model 99640. When I used it, it shot out 2 'L' shape cleat (16G, 2") at the same time instead of 1 cleat. I tried to minimize the gap for the mouth, it end up jamed. Anybody has this experience and know how to solve the problem? Thanks a lot!
    President:
  • Craftsman Master
  • 1,388 Answers
I have noticed that some nailers with this problem have a driver blade that is slightly wider than the width of the cleat thus allowing the driver to actually hit part of the second cleat in the strip. To fix problem the driver blade should be slightly trimmed or tapered. File/grind the driver only on the side facing the cleats. Remove only enough metal to allow driver to hit only one cleat. Taper the grind up about 1/2 inch. This tapering is used on many different drivers including fraiming nailers to prevent the driver from hitting second nail on strip (mainly clip head nails). Only other remedy is to find thicker guage cleats that will still fit thru nose. Good luck with your repair
Posted on Oct 09, 2010
Testimonial: "Great help, thanks"
.CENTRAL PNEUMATIC staples go right through insulation paper how to adjust
quite likely still too much pressure .personally I prefer a slam hammer stapler for that task .
Nov 19, 2017 | Staples Tools & Hardware - Others
How do I find a manual for central pneumatic 2-in-1 18 guage brad nailer/stapler kit 2 item 97524/40116?
Unfortunately, harbor freight retires nail gun models very often. They only list the current nail gun models on their web site, thus manuals and parts are only available for a short time. The only help is that the new models are similar to the old. Sometimes the internal parts are the same but at least the user instructions should be the same. Download various manuals from similar models on their web site today and compare. Do not order parts unless you are sure about fit. As far as orings, you can use generic also from harbor freight (oring kits in standard and metric, not expensive).
Good luck
Feb 15, 2015 | Air Tools & Compressors
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
I used my Power Shot twice after I bought it brand new. The spring mechanism for the handle to reload seemed to be malfuctioning. I was in the middle of remodeling my home so we ended up using my workers...
I had one also that jammed all the time. Without knowing the date of purchase, the only options you have would be to invoke the manufacturers warranty (should be on the package it came in) or just toss it and get another (which is what I did, mine was 3-4 years old). I did find that though this model is ok for the handyman or weekend user, for contractor or heavy use, this is not a good model. The warranty information on the package will tell you what to do. If you don't have the package and yours is relatively new, go to the store and get it from another like model. Good luck.
Aug 05, 2011 | Black & Decker 5700 Powershot Forward...
The nails will not drive into the oak flooring! the compressor is at 100psi and the nail gun mis fires or when it does fire it only drives the nail 1/4 inch into the flooring. It is a Akuzuki x-799
I am not familiar with that name of nailer but when I have run into that problem it was because of too much oil used in the gun. If so this will have to be cleaned out. You do not have to oil a gun every time it is used if not used consistantly for long periods of time. Also are you using the proper guage nails? Something to consider hope this helps.
Apr 25, 2011 | ProSeries Akuzuki Contractor Pro Series...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Will a Central Pheumatic framing nailer model # 98733... 21 degree use a 2 in nail? I seen in the instrustions only use 2-3/16 to 3-1/2. I have a lot of 2 in nail. Thanks John
As with all tools - following the instruction manual is for your safety as well as to not cause damage to your tools. Glad to see you read the manual - some do not and get hurt because of it. Please do as the manual instructs - it may keep you, as well as your tools, in good working order. Be safe. Hard to frame from a hospital bed.:-)!
Jan 16, 2011 | Tools & Hardware - Others
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I have a bad air leak around the head of my floor nailer.
It is very possible that you can, however, there is usually no way to look it up. If you have access to a dial caliper, measure inside the groove as good as you can. Take that measurement to your local auto supply store or fastener center (or even a well stocked hardware store and give it a try. Without measuring it I have no way of telling you for sure, but I do that sort of thing all of the time -- I just made a bushing for a garage door opener today out of a piece of copper pipe -- the measurements were exact. The only way to know for sure is to measure it.
Dec 08, 2009 | Air Tools & Compressors
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board....
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Aug 02, 2009 | Stanley Bostitch Industrial Manual...
Air Tools & Compressors Logo
396 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
