Question about Kitchen Appliances - Others
Pitco 35cs pilot won't stay lit when you let up off the button thanks for your help
    Champion:
  • 248 Answers
May not be holding in long enough,try 30 seconds.If it dont work may be bad thermalcouple.
Posted on Oct 08, 2010
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
Jul 09, 2014 | Pitco Frialator 35CS Deep Fryer
Pilot light will not stay lit once pilot button is not depressed. Replaced thermopile already. Any suggestions? Also don't have milivolt detector. Thanks
Hi there.
Check the wiring, loose wiring terminals can disrupt the current going to gas valve.
Try also to connect jumper wire across the hi limit terminals, if this do the trick, replace the hi limit device before operating the fryer.
Lastly, the gas valve may be defective.
Regards.
Nov 26, 2013 | Pitco Frialator 35CS Deep Fryer
My pilot light wouldn't stay lit. After lighting the pilot for 2-3 mins. whole frialator would go off including the pilot...
Hi there. Check the hi-limit control, it may be tripping prematurely and needs replacement. Regards.
Oct 31, 2013 | Pitco Frialator 35CS Deep Fryer
Pilot won't light at all on Pitco Frialator.
Would not be a good plan to do this your self gas valve replacement is a gas fitters job
May 25, 2012 | Pitco Frialator 35CS Deep Fryer
My pilot lights, but the burners don't stay lit. they puff on for a second but go right out what should I check?
Hi there.
Make sure that all wiring connections are tight.
Check the continuity across the hi limit terminals.
Also check the thermostat setting.
Regards.
Sep 06, 2011 | Pitco Frialator 35CS Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light does not stay on
Hi there.
Try cleaning the thermopile, it must be free of soot or any form of dirt. Ensure that the gas pressure is sufficient, all wiring connections are tight and the hi limit is good.
If all of these are okay and the pilot still wont stay lit, try replacing the thermopile.
For Owner's manual download that will help you in minor fryer troubleshooting and reference, visit http://www.pitco.com
Regards.
Jun 27, 2011 | Pitco Frialator 35CS Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
I have a Pitco 35cs that I obtained from a place that was closing. I have hooked it up to my BBQ gas stack and I have no knowlege of how to make it work. I have left it hooked up but won't try to start...
first make sure you have a 1/2 psi regulator. If you do, turn the main gas valve to "pilot" and hold it in. The pilot area is behind the burners if you're kneeling in front of it (has kind of a Y shape). while continuing to hold the knob in try to light it every few seconds until it stays burning. keep holding the knob for about 30 seconds and slowly release it. the pilot should stay lit. turn the knob to "on" and set you're desired temp from the TSTAT.
Nov 16, 2010 | Pitco Frialator 35CS Deep Fryer
Kitchen Appliances - Others Logo
60 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
