Question about Diamond Multimedia ( VC500) Video Capture
Diamond vc500 capture screen shows analog picture on only the top 80% of the available screen. The output digital video is only the top 80% of the original analog video. How do I fix this?
When mine does that, I just turn it off and on again. That usually works.
Posted on Oct 28, 2010
Ok I have my vc500 and im trying to record my xbox 360,but it mostly shows fuzzy or no signal on the computer.Then I try to record my wii and it records but in the middle of recording it pops-up "No video was captured.Please check if there is any input signal.There may be no device selected",and then the video freezes.
If anyone can help it will be very nice. Thanks
Posted on Mar 30, 2011
What's wrong with my capture module on my vc500 cxt adapter, audio but no picture
I can't give a solution. I am having the same problem. Used the capture device a few months ago and it seemed to work. Now I can't get the computer to recognize the USB device and I get the same message. Anyone out there that can help?
Dec 05, 2012 | Diamond Multimedia ( VC500) Video Capture
Vc500 sound but no video
A possibility is that you are set to the wrong video source (for example, the S-Video instead of the composite).
The second possibility is that you are set to be "PAL" capture for an NTSC source or vice versa. If you are in the US, set NTSC. If anywhere else, select PAL.
Nov 20, 2011 | Diamond Multimedia ( VC500) Video Capture
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
I am using the vc500 to capture video. It works except
That is a frequent 'fault' with the low cost capture units.q Nothing can be done, other than seeing if Diamond has a newer driver that corrects it.
Jan 25, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Aug 26, 2008 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
772 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Lawrence Oravetz
David Gust
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
