How to remove wire protcetion in usb flashdrive
  • 4,336 Answers
Somewhere on the unit is a little teeny tiny switch. You have to find it. I presume you mean write protection.
Posted on Oct 08, 2010
Acer Aspire 4736z always shutdown on start-up
Try to update your BIOS. Download it here : http://us.acer.com/ac/en/US/content/drivers
You must need USB Flashdrive to update it. Please make sure that your USB Flashdrive is bootable. Here's the link on how to make USB Flashdrive bootable: http://www.makeuseof.com/answers/usb-drive-bootable/
After you make your USB FLashdrive bootable, copy that BIOS update folder in your USB flashdrive. Please also rename it in simple words so that you can easily access it using command prompt. And after that make your USB flashdrive as first boot priority. Then save and exit.
When the USB flashdrive is now booting.
Type this:
cd (name of the BIOS Folder)
cd DOS
FLASH
then wait it after it finish.
NOTE: Make sure you plugged in your AC adapter.
Hope it helps
Feb 22, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Tip
How to change ps3 background
if you have a picture on the computer u would love to have as a ps3 background , you would either need a laptop/pc with bluetooth or a USB flashdrive . place the picture on the flashdrive then stick it in the ps3 . when on the ps3 scroll along to Photo then go to USB Flashdrive and click on it . the picture should be there , if there is nothing there press triangle on the USB Flashdrive and select , DISPLAY ALL . then locate your picture
on Mar 01, 2010 | Video Game Consoles & Games
How to download on verbatim flashdrive
Hi, if you want to download to the flashdrive, or external memory device you are able to "Browse" the location you would like to usually before downloading, like something from the internet. If you are trying to save pictures from your computer onto your USB flashdrive you can right click your picture, select copy then goto your start menu and select & open your USB drive, then right click and paste into the window or a folder that you have created. To create a folder on your USB, just right click into a blank space in your USB window when opened, and select NEW, then Folder =) Hope that helped
Feb 17, 2013 | Verbatim Electronics - Others
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
My camera wont let me take a pic it says sd protceted
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 26, 2010 | Polaroid A500 Digital Camera
How to remove the copyright in my flashdrive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flashdrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I plugged my LG USB flashdrive into my laptop last night and laptop said that there was a USB malfunction. I had just used the flashdrive on a desktop. The flashdrive does not light up either. Is the...
Try the flash drive in another computer, if it works then backup your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 22, 2009 | Electronics - Others
The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Jan 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB Flashdrive shows full
Format your USB flasdrive..
Go to My Computer
Right click on removable disk and click the format..
Nov 19, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
