Question about Airlink AR430W Wireless Router
I have an Airlink AR430W router and I'm trying to secure it. When I type 192.168.1.1 in the browser it says the connection typed out and when I type ping 192.168.1.1 in the command area it says the same thing. I am currently using a MacBook Pro. Any suggestions?
  • Airlink Master
  • 7,733 Answers
Go to http://airlink101.com/download/download_links/q-ar430w.pdf
Posted on Oct 10, 2013
pamthegreek
  • 148 Answers
SOURCE: Router trouble
See:
http://www.airlink101.com/download/download_links/q-ar430w.pdf
Posted on Jul 17, 2008
voodoomox
  • 1689 Answers
the way you describe your router's status, it looks like its starting to go out on you, or its gone out. the ports on the router should have the same activity when you plug a computer to it. there is a possibility that the chipsets of the router inside got fried during the outage and the pwoer surge. sometimes surge protectors are not enough, you have to have a UPS to protect the devices. if in case it is best that you contact the macnufacturer of your router or your ISP so that they will be able to transfer you to the right line.
you may also want to consult your devoce's warranty status.
Posted on Aug 12, 2008
sardanadixit
  • 813 Answers
SOURCE: airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Posted on Jul 08, 2009
SOURCE: Airlink AR430W wireless router stopped working
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Dec 06, 2009
  • 211 Answers
SOURCE: every 2 or 3 hours connection lost on
try upgrading the router firmware !
Posted on Jan 10, 2010
The password for my Airlink 101 AR430W says it's incorrect.
Try this http://www.fixya.com/support/r11153882-general_routers_reseting
Jan 29, 2012 | Airlink AR430W Wireless Router
I have no software to control AR430W wireless router
YOU DON'T NEED ANY S-WARE JUST A BROWSER.GO HERE TO USR MANUAL AT http://airlink101.com/download/download_links/q-ar430w.pdf
Nov 25, 2011 | Airlink AR430W Wireless Router
My Airlink430W is not connecting to my laptop the keys changed and I do not have them anymore.
Connect to the router by typing the IP address of the router into a web browser. Then go to the section dealing with wireless wep or wap security. Change the key there to something you will remember. If you cannot remember the administrative password of the router itself, then reset the router and reconfigure it.
Sep 02, 2010 | Airlink AR430W Wireless Router
I purchased the Airlink 430W on Friday. After
May 12, 2010 | Airlink AR430W Wireless Router
Lost pass word to router airlinks101 ar430w
just reset the router and things will be as new . or try the ipconfig in the cmd in the run box. take the default gateway and put it int he browser window . Then try the default username and password.
Oct 20, 2009 | Airlink AR430W Wireless Router
Airlink ar430w not giving a network address to netgear wpn111
Jul 08, 2009 | Airlink AR430W Wireless Router
Lost password
You have to be at the router to do this.
1 - Find the reset switch on the router (should be on the back). That will reset the router to factory defaults.
2 - Using a web browser, type in the address 192.168.1.1 - this will get you into the router's web management interface.
3 - Log into the router. User name is "admin", password is "admin". Once logged in, change those, and set your router up again.
There is no way to recover the old password, if you forget it. Sorry, but that is for your own security.
Cheers
Sep 21, 2008 | Airlink AR430W Wireless Router
Open Questions:
Airlink AR430W Wireless Router Logo
141 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
