Question about Vizio GV47LF Television
Buzzing/humming and dimming screen from right side of Vizio Gallevia 47
4 Suggested Answers
SOURCE: Black square on the screen Vizio Gallevia 47" 1080p
I had the same problem on certain channels. Some black squares would appear int the lower right area of the screen. I believe it is now corrected.
It looks like a may have had a close caption option on. I think it was CC3. Turn CC to off. This should correct the problem.
Posted on Jun 20, 2008
SOURCE: Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
Posted on May 19, 2009
  • 5128 Answers
SOURCE: How can you tell if the bulb on a vizio gallevia
LCD TV's don't have a bulb. They have backlights (usually compact fluorescent tubes) and a panel of LCD pixels. So you can have one of three things fail: the video board, the inverter that drives the backlights or the backlights themselves. If the problem happened suddenly the inverter is more likely to have failed. As the backlights fail, the screen slowly dims or the image will become pink/red. Look closely at the screen, if you see a dim image then the backlight has probably failed (block the room light but try looking with a flashlight from a few inches away from the screen). If you see nothing, the inverter or the video board are more likely suspect.
For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Sep 22, 2010
Vizio Gallevia can't see whole picture
Check the button for picture size and adjust accordingly.
Sep 18, 2015 | Shopnbc VIZIO Gallevia 46" 1080p LCD HDTV
Buzzing from speakers
Audio output card has damaged. Replace it.
Oct 11, 2012 | Vizio Gallevia GV42LF 42 in. LCD...
Whe is the mother board on a vizio gallevia tv
Usually there are only about 3 or 4 boards in an LCD TV. the mother board will be the large one that usually also has the HDMI and AV connectors on it. It will not be the one that the power cord plugs into.
Sep 20, 2012 | Vizio VO47L 47 in. LCD TV
I have a 47 in Vizio that the backlight is very dim and flickers like a fluorescent light. There also is a buzzing noise in the back panel. The Tv is out of warranty. I want to know what needs replaced?...
You probably have some defective capacitors on the power supply or inverter circuit boards. Hopefully they will be swollen and easy to find. Otherwise, it take a tech to figure out which is bad.
Jan 30, 2011 | Vizio GV42L 42 in. LCD Television
When I turn on my Vizio Gallevia 42" tv it Just Shows a Blue screen and no signal then turns off
Have you got anything connected to the TV? If so, make sure they are powered on, and all connected correctly.
Hope this helps
TV_Doctor
Jan 03, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
Hi, My Vizio Gallevia 42 is showing a "no signal" message and then shutting itself off. Do you know what that means?
Dec 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
May 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Vizio GV47LF Television Logo
124 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
