Remove power on password on my HP laptop - Computers & Internet
  • 4,340 Answers
You can do this, but you need the original password, then use blanks for the new password.
Posted on Oct 08, 2010
Power-on password on hp 8510p
Power On Password & Hard Disk Password
With your next laptop you should protect it with a Power On Password AND put a password on your hard disk. This will stop anyone from using your laptop and if they move the hard disk from your laptop to another laptop they cannot access the data on your hard disk with the hard disk password.
BUT you need to write down or remember these passwords; if you lose or forget them you cannot gain access to your laptop.
There are no backdoor passwords to remove these passwords.
To set up or change these passwords, go to the BIOS configuration - then security configuration. http://techtips.salon.com/reset-hp-laptop-bios-password-1476.html
Nov 26, 2012 | HP Compaq 8510p Notebook
Bio passwod removal hp laptop
How to Reset an HP Laptop BIOS Password
Reset the password on any HP laptop.
Reset the BIOS password on an HP laptop computer when it has been forgotten or when preparing the laptop for sale to a new owner. Learn how to erase an unknown BIOS password by physically disconnecting the internal batteries. Avoid spending hundreds of dollars at a service center to make changes that can often be performed at home by anyone with the ability to take an HP laptop apart and put it back together again.
Items you will need
  • Small screwdriver set
  • Flashlight
Step 1
Power down the computer if necessary by holding the power button down for six seconds until the power shuts off.
Step 2
Disconnect the power cord from the HP laptop computer. Remove the battery by flipping the computer over onto its cover and releasing the battery clips as indicated by the illustrations on the bottom of the laptop or in the owner's manual. Lift the edge of the battery nearest the clips up first, then pull the battery out of the laptop.
Step 3
Remove the screws that hold the hard drive cover in place and remove the cover. Take the hard drive out of the laptop by removing the two retaining screws and pulling the drive gently away from the connector, then lifting the hard drive bracket or tray out of the computer.
Step 4
Remove the screws that hold the memory compartment cover in place, then remove the cover. Remove the memory modules from the sockets by spreading the metal retaining clips gently apart and allowing the module to spring upward. Pull the memory straight out of the socket at the angle it rests at when sprung from the retaining clips.
Step 5
Remove the Real Time Clock (RTC) coin cell battery from the memory compartment by pressing the retaining clip and pulling the coin cell battery out of the socket.
Step 6
Allow the computer to sit without the battery for an hour, then reinstall the memory and hard drive, but leave the coin cell battery and the main battery out of the system. Connect the AC power adapter to the system and power it on to clear the BIOS password.
Step 7
Power the system back down and remove the power cord to reinstall the coin cell battery and main battery.
hope this helps
John
Nov 17, 2012 | Microsoft Windows 7 Home Premium 64BIT...
The hp probook 4510s laptop is prompting for bios password upon start up
IF you set the BIOS password then when you power on the notebook it you would be ask you every tiem BIOS password and not if you want to remove bios password then go in BIOS utility then remove bios password
Aug 20, 2011 | HP ProBook 4510s FM849UT Notebook
How to remove power on password? model# HP dv3-1075us thanks
do u mean to remove the power to reset the password because u don't know the password, if this is the case, you need to remove the internal cmos battery inside on the motherboard then put it back in, this should reset the password, if you want the box that comes up asking you for a password, then you need to go into the bios, and look for password, and disable it, to go into bios, when your laptop is booting up look for press F2, F12, F5, to enter setup, each laptop is different, might be F8, F9.
Sep 24, 2009 | HP Pavilion Dv3-1075us Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
Hp nx 6110 a power-on-password
Hi, try this:
- unplug from mains
- remove laptop battery
- remove real-time clock (CMOS) battery.
- wait 5 minutes
- replace the RTC battery and then
plug in - without the laptop battery.
The laptop battery cannot be present
when you remove the RTC battery
and shouldn't be there when you power on.
Try
Mar 31, 2009 | HP Compaq nx6110 Notebook
I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Feb 18, 2009 | HP Compaq nx8220 Notebook
HP nc6320 BIOS Power on Password
You Have to Remove RTC battery ( Cmos ) battery.
Wait approximately 5 minutes
Replace the RTC battery and reassemble the computer
Connect Ac Power to the computer. Do not reinsert any batteries at this time
Turn On the computer
all the passwords and all the cmos setting have be cleared.
Aug 12, 2008 | HP Compaq nc6320 Notebook
How to reset power-on password.
The only way is to clear the cmos settings. However, there is a special way to do it. First you have to take out the battery and the power adaptor from the laptop. Then you need to open the laptop and look on the main board for the cmos battery. Take it out for a few minutes, maybe 5 - 10 minutes. Then plug in the power adaptor without the cmos battery nor the laptop battery and boot the computer. It will ask you to hit F1 to either load default values or to save settings. Do that. Then shut down the computer. Make sure settings is saved though. Put in back the cmos battery and the laptop battery. When you reboot, it should boot up with no password.
May 02, 2007 | HP Compaq Business NX9110 Notebook
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
