Need to fit picture to screen size ratio... there are some words that are unable to be read because the ratio is not correct.
  • Christal Vaughn Oct 08, 2010
    thank you. I dont know what i did with the manual. How do i go about obtaining one of those
    President:
  • 2,777 Answers
This sounds like you have ZOOM mode enabled on the TV. Look for a zoom button on your remote, there should be one. If you can't find it and can't get it unzoomed please respond here with the make and model number of your TV.
Thanks
Tim
Posted on Oct 08, 2010
Why cant I get it off of wide screen? Everyone's head are cut off and can not read subtitles at bottom.
the aspect ratio is the picture size control
when you select aspect ratio you have to move with the arrows to get the size that fits the panel the best - go ok then exit to save the setting
if that doesn't work the the tv will need attention in a repair shop
Sep 03, 2015 | Televison & Video
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
Why will my picture not fit on the Lg 5100 led tv?
look up your instruction book and get the menu up on the screen . . will be a thing in there for the screen size . . make sure it is set on correct size
Jun 01, 2014 | LG 55LN5100 55" LED TV 1920x1080, 120 Hz,...
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way...
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Aug 23, 2011 | Vizio 42 in. LCD TV
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Need to fit picture to size on screen. Some of the words are not within the screens ratio.
Use your remote and hit munu... then change your picture size until you can get the right size for your program.
Oct 08, 2010 | Vizio VX37L Television
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
