Question about Crown XLS202 2Channel Amplifier
Crown amp had 2 shorted output transistors.and 1 blown cap.i replaced all.still will not turn on. circuit breaker is fine.what usually goes wrong with these amps? where do i check now?
  • 4,234 Answers
There is a "driver" stage that sets up the voltages for the output stage as well as a bias circuit. Any of these can have a problem. I would suggest that you take voltage readings at each of the output transistor pins and post the readings here. I might be able to give you a few things to check. Crown designs are not the simplest to diagnose, but we should be able to track it down a bit. Measure each of the pins to gound and post the values here.
Thanks,
Dan
Posted on Oct 10, 2010
Power indecate foulty
Most likely one or more pairs of the output transistors is shorted. The amp is attempting to drive a signal into a 0 or low ohm load. This unit should see a service center for repair.
Dan
Jan 10, 2010 | Crown XLS 602 2-Channel Amplifier
I have blown the protection circuit on my yamaha rx 600d amp anyone with a clue whats needed to fix?
Hi friend,when something goes wrong in the output of the amplifier the protection circuit take place to prevent further damage could cause by DC power such as speakers or other related circuits...I think in your situation either one or both output amp stage have blown,then the protection cct turned on (not blown protection circuit!?). If so you have to check all the output transistors for short cct, if shorted you must also check all the DC bias cct nearby such as small transistors,resistors...If you are not familar with amplifier it better to find a tech as all amplifiers need a very precide repair technic , If the DC BIAS were wrong , when you turn on the power it will blow straight away! All times and cost will be waisted!
GOOD LUCK!
Tan Ta
Nov 23, 2009 | Yamaha Audio Players & Recorders
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Amp powers on, no sound from subs
the output is blown. It is in need of service.
Dec 28, 2008 | Alpine MRD-M1005 Car Audio Amplifier
80 watt impedance matching volume control
check your spekaer cabling first for any loose connection. if everything as usual then something is wrong with either your speaker system or the power output stage of your amp. you may call it a "circuit breaker" but it actually overload protection of the power amp so as not to damage speakers or amplifiers. have your speakers checked for burn coils. you can also try to remove or turn off speaker switch, turn on the power, level up the volume and see it the system still stays on and does not trip (as you called circuit breaker) if the unit remains on, then it must be your speakers. though it could also be a leakage in the power transistors of your output stage, it something a technical person have to do to check anyway.
redrivera
Mar 25, 2008 | Audio Players & Recorders
JVC AV-36260 Is there a fuse in this TV or is it a circuit breaker, if it is where is the fuse / circuit breaker located. I am am electrical engineer, but can not find any specs on the inside of the unit
All modern TV's have fuse devices,some glass,some chemical.
However,a blown fuse comes from a short circuit,which I'm sure
you are well aware.Let's talk diagnosis--What is your set doing
or not doing?? Is it dead?==No "on"?? If there is no bad fuse,the
most common solution is a bad capacitor in the power circuitry
number sequence==900's. Ex..C953    value== 1000mf/35v.
Other caps in power supply may be weak.
2) Check Horiz output transistor---shorted? Look for blown B+
fuse + weak or open C523 1mf/160v in horiz drive circuit.Replace
horiz out with high-quality OEM transistor only.I use JVC only
on 32" size & bigger ( you have 36" ).
  Let me know by rating this solution...thanks...T.
Oct 22, 2007 | JVC AV-36260 TV
Crown XLS202 2Channel Amplifier Logo
196 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
