Question about GPS
Dear sir. the ACS 800 drive trip with 3130 fault frequently, cheche all fuses and voltages all are ok. pl suggest.
3 Suggested Answers
  • 319 Answers
SOURCE: power fault
You probably have shorted rectifiers and/or transistor(s) on standby board. Trouble-shoot rect bridge and cap. Feel stand by circuit transformer for abnormal heat, sure sign
Posted on May 01, 2008
ZJLimited
  • 17970 Answers
SOURCE: Chech engine fault PO108 Circurt High Voltage
The Engine Control Module (ECM) has detected a performance fault with the Manifold Absolute Pressure (MAP) sensor
The Manifold Absolute Pressure (MAP) sensor provides instantaneous manifold pressure information to the engine's Engine Control Module (ECM). The data is used to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering for optimum combustion. A fuel-injected engine may alternately use a Mass Air Flow (MAF) sensor to detect the intake airflow. A typical configuration employs one or the other, but seldom both. .
Symptoms of a P0108 DTC code may include:
MIL (Malfunction Indicator Lamp) will likely be on
Engine may run poorly
Engine may not run at all
Fuel mileage may decrease
Presence of black smoke at exhaust
Potential causes of a P0108 code:
Bad MAP sensor
Leak in vacuum supply line to MAP sensor
Engine vacuum leak
Short on signal wire to PCM
Short on reference voltage wire from PCM
Open in ground circuit to MAP
Worn engine causing low vacuum
Possible Solutions: A good way to diagnose if the MAP sensor is to blame would be to compare the KOEO (key on engine off) MAP sensor reading on a scan tool with the Barometric pressure reading. They should be the same because they both measure atmospheric pressure.
If the MAP reading is greater than 0.5 volt off of the BARO reading, then replacing the MAP sensor would likely fix the problem. Otherwise, start the engine and observe the MAP reading at idle. It should normally be about 1.5 volts (varies according to altitude).
a. If it is, the problem is likely intermittent. Check all the vacuum hoses for damage and replace as necessary. You can also try wiggle testing the harness and connector to reproduce the problem.
b. If the scan tool MAP reading is more than 4.5 volts, check the actual engine vacuum reading with the engine running. If it is less than 15 or 16 in. Hg, then the PCM is probably not seeing enough vacuum (due to a worn engine, perhaps) for a given operating condition (which causes a higher than normal voltage signal to the PCM) and setting the code. Repair the engine vacuum problem and retest.
c. But, if the actual engine vacuum reading is 16 in. Hg or more, then unplug the MAP sensor. The scan tool MAP reading should indicate that there is no voltage present. Check that the ground from the PCM is intact and also that the MAP sensor connector and terminals are tight. If the connection is good, then replace the map sensor.
d. However if, with KOEO, & the MAP sensor unplugged, the scan tool shows a voltage reading, then there may be a short in the harness to the MAP sensor. Turn the ignition off. At the PCM unplug connector and remove the MAP signal wire from the connector. Re-attach the PCM connector and see if with KOEO, the scan tool MAP reading shows voltage. If it still does, replace the PCM. If not, check for voltage on the signal wire you just removed from the PCM. If there is voltage on the signal wire, find the short in the harness and repair.
Hope this helps; keep us updated and remember to rate this answer.
Posted on Apr 15, 2011
What would be the solution for six red light blinking after switch on the tv?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
May 14, 2014 | Sony BRAVIA KDL-46EX700 46" LED TV...
HOOVER HNF 7147. BLOWS THE HOUSE RCD ONLY WHEN ON A WASH CYCLE AND NO WATER BEING FED INTO DRUM. I SUSPECT THE HEATING ELEMENT IS DRAWING TOO MUCH DUE TO NO WATER IN THE DRUM. BOTH INLET VALVES ARE OK AS I...
You need to check the circuit in the wash cycle. Disconnect the power to the heater coils and see if the fuse trips. Also the voltage at inlet solenoid must be checked when the program cycle is on the wash , is not the program controller board is fault, possible a wrong output from the processor.
You can isolate the circuits, the heater, the motor drive to see if the trip stays. Also check the inlet and the drain pump on a test bench to confirm the working of the valve which will infer the case.
Sep 16, 2011 | Hoover Washing Machines
My maytag dishwasher apparently blow a fuse in Fuse Box. I then throw the switch it worked ok, next day or two my wife try to start the dishwasher it would not turn on. I bought new fuse to put in...
It seems you may have an Electrical Insulation Break Down fault with your machine.
My suggestion would be to get a Registered Appliance Technician to test the internal circuit of the machine before attempting to switch on the appliance or rectify any fuses.
The appliance needs to be issued with a (PAT) test first to determine if the appliance is safe to touch when applying power to the machine so you dont electrocute your self.
Once the (PAT) test has been applyed then the technician can visually inspect the high voltage internal parts that could be the result of the insulation break down.
I strongly suggest if any kitchen appliance trips the main fuse for any reason I would recommend not trying to change any fuses as this second atempt to reboot the machine may have blown the machines 'Power Control Module'!
Apr 30, 2011 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dear Sir, My Nokia 6300 mobile screen is undisplayable . It is good working. Pl suggest : 1 weather it is repairable 2 weather screen will be changed then what is it cost Awaiting your...
yes you can repair the screen
it will cost you as per the standard of repairing if you get it repaired from a local shop in india you may be charged in between Rs.400/- to Rs.800/- and if you get it repaired from the authorised nokia showroom it will start from Rs.800/-
Jan 13, 2011 | Nokia 6300 Cellular Phone
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
I want to install a 48" dual fuel range and I need to know the voltage and amperage to get the proper outlet and plug. It is also set up for propane and I'm hooking it to natural gas, I'd like to know if I...
YOU DON'T SAY IF THIS IS A DACOR CONCEPTS PRODUCT OR WHO MAKES IT..
IF IT IS, CALL THESE NUMBERS..
Dacor 1440 Bridge Gate Drive
Diamond Bar, CA 91765 Toll free: 800-793-0093 Main: 626-799-1000 Fax: 626-403-3130
Dec 18, 2008 | Dacor Epicure ER48D Stainless Steel Gas...
Aopen motherboard: MS-6378 VER:3 Faulty
just u clear the cmos and load the defaults settings in bios then  restart the computer.,if not check the cmos voltage +3v,if voltage not appear pl change the battery it self
Was it helpful to u pl give the rating for me
Thank u
Oct 23, 2007 | AOpen AX34-U Motherboard
GPS Logo
75 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
