Question about Brother MFC-9440CN Laser Printer
Paper jam error, but there is nothing jammed.
  • 6 more comments
  • junk210 Oct 08, 2010
    I did all the basic steps. I have a degree in IT, and have a technical knowledge of hardware. There is no paper jammed. There is no message, when the printer is idle. It happens when I try to print. The error message appears as soon as the paper gets into the first roller. I checked that the roller holds the paper well. It looks like a sensor or other electronics gives a false signal.
    I also cleaned the sensors before. When I try to feed the printer through another tray it causes the same error, it tells either "JAM TRAY 1", or "JAM MP TRAY", depending on which tray I am trying to use. It looks like the sensor recognizes the paper properly, but something else is causing the error. Thank you
    I did all these steps. It does the same when you try to copy, so it is not related to the computer setup in anyway. If you believe it has something with the printer configuration, or its memory, then maybe you know a maintenance code to reset the printer, or firmware? Thank you.
    MFC-9440CN. Please read previous posts, before asking me again to unplug the printer from the power, as all the basic steps were done already. Thank you for your help.
    I checked paper jam already very well. The error does not come up after re-powering the printer, until I try to print. Also left the paper between the rollers and re-powered the printer. Bottom line: when I power on the printer with the paper left between the rollers, It gives the error, which is proper in this case. However when there is no paper left, the printer does not give error on re-powering, until the printing. Thank you.
    The idea of resetting the printer sounds good, but the procedure you provided is probably for another printer. This one does not have a power button. It only has an electric switch. I know there there are maintenance codes you can access by powering on and holding MENU key. However, I don't know what means each of the numeric codes, and which one would do a hard reset.
  • junk210 Oct 11, 2010
    I would like to know the maintenance code to reset the printer.
    I did the reset, and the problem persists.
    In the feeder is a sensor to detect if the paper is getting into the roller. As soon as the paper touches this sensor, the paper stops moving and the error comes up.
  • 2,973 Answers
Use your vacuum cleaner to suckout the dust from powered off printer. There may be some speck of paper lying around in the channel somewhere.
Posted on Oct 12, 2010
    President:
  • 8,637 Answers
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Oct 11, 2010
    President:
  • 1,216 Answers
Has the machine recently started to jam more often? If so, it could be a worn belt and/or worn fuser drive gear.
See if this is a problem.
Anyway, you might try a forced reset. Check the manual. You usually have to simultaneously push a couple or so buttons on the control panel to force a reset.
If you don't have the manual get it here.
if this does not do tell me and we should check some other components
Posted on Oct 09, 2010
    President:
  • 4,070 Answers
Hi! Please turn off your printer and unplug it from power sourced. Press/hold the power button for 10secs. while the machine is unplugged to reset the system. Plug the printer, turn it on and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Oct 08, 2010
  • 712 Answers
Before concluding that there are no jams, try to open every parts of the printer that you can to enhance your view and have a thorough check. Even a small bit of paper can cause the error 'Paper Jam'.
    President:
  • 2,777 Answers
First thing, but you probably have already tried, is to just unplug from the power source for at least 2 minutes.. then replug. I assume you've done this though correct?
Also, what make / model printer is it to confirm?
Tim
    Genius:
  • 1,456 Answers
Hello
Check the printer for any jams or blockages, and remove any that exist.
Delete any print jobs in the queue. Go to the printer's control box and double click on the printer you want, then select any print jobs and select "Delete."
Turn the printer completely off and unplug it. Wait about 30 seconds and turn the printer back on.
Restart the computer. Close all your programs, shut down the computer and wait a few seconds. You may want to turn the printer off again. Restart the printer and the computer.
Go back to the printer panel and select the printer, and then select "Delete." Select the "Add Printer Wizard" and add the printer again.
Download the latest drivers by going to Brother's website and finding the latest driver revisions. Right click on the printer, and click "Properties." Look in all the different tabs to find a button that says something similar to "New Driver" or "Update driver." After selecting, point the wizard to find the new drivers that were downloaded.
  • 3,530 Answers
I am pretty sure you have done the basics to troubleshoot this problem including the universal rule of powering it off and powering it on after 30 secs.
Clean the sensor with a canned air. There could be toner, paper dust, shredded paper or what not's that is blocking it. It is also possible that the paper sensor may have shifted or became loose due to rough handling during shipping. .
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
  • 503 Answers
  • 1
    Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • 2
    Turn off the printer.
  • 3
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • 4
    Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • 5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • 6paper jam error, but there - clear-printer-paper-1.6-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); });
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • 7 jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); });
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • 8
    Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • 9
    If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
    Hi tkasirye,
    Welcome to Fixya.
    You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
    1. Error Codes - Toshiba 2860
    1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
    Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
    Hope this helps.
    Takasashi
    Jul 05, 2011 | Toshiba Office Equipment & Supplies
    My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    Jul 04, 2011 | HP LaserJet 5100 Printer
    HP PSC 1610 - Keep getting paper jam error with no paper jam.
    Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
    Error code E-04
    I would check that there is nothing inside the paper feed system. The smallest piece of paper might cause a jam. Take the inks out and give the printer a good shake then put inks in and try again.
    IHave you had a jam recently and pulled the paper out to clear it?
    Jan 10, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    Paper jam error nothing appears to be in there.
    Kept messing with the printer. Took some of it apart. Changed out cartridge. Still found no jam. Turned it on and off multiple times.
    Finally it worked. Prayer is all I know that worked.
    Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    Paper jam
    please chack your printer paper feed sensor
    sometimes it displace position then paper is missfeed
    Aug 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Canon MP470 printer jam error
    hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
    Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Carriage jam on HP Photosmart 3210 Printer
    most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
    Dec 13, 2008 | HP Photosmart 3210 Printer
    "Clear paper jam" error, but there is no jam!
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    prirweto-i-23
    Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Paper Jam
    try a test page..and see if that flows..
    Aug 20, 2008 | HP LaserJet 2100 Printer
    Brother MFC-9440CN Laser Printer Logo
    287 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
